2017 Superduty CB/UHF/VHF Radio mount location
I also don't have the full center console, and mounted my 2 meter radio on the floor using a pedistal mount that I had purchased off eBay about 10 years ago to mount it in my old f150. Blocked off the little storage bin and the extra 12 volt plug that was there but I hadn't found a use for them in the 2 weeks I had the truck before I mounted it and figured I wouldn't miss it. That spot also allowed me to still use the left side of the lower cup holder for larger coffee cups. Mounted the antenna via a lip mount to the rear edge of the hood.
I've got a Stryker SR-89MC I used in my Jeep Wrangler. It can be mounted anywhere. I just haven't decided about an antenna setup on my truck yet. The Stryker SR-89MC is a great little radio and performs very well.
https://www.youtube.com/watch?v=qq5SJB3Jnok&t=24s
I just installed one on my 2019 f-250. I pulled off the plastic side panel on the driver's side of the center console and screwed the unit to a bracket behind that panel up near the firewall. Fits in there real tight but its 100% hidden and no holes required if you don't want to. I did cut one hole to run the mic cable out the front of the panel under the cover for the mounting bolt of the console itself. The mic cable lays right in the space along side the console. Looks like it was factory. It's not necessary if you don't want to. I just thought it really looked and worked well enough to drill the hole.
I bought a fender NMO mount for a Larsen 5/8 wave antenna I had...hope a 5W HT coupled with the external antenna will be adequate for the repeaters in my immediate area.
W7PSK
6.7L Power Stroke Diesel
04-26-2012 05:43 PM
KC8QVO
05-30-2011 09:05 PM
