Sponsored by: Real Truck
Tire Size question....
Old Jun 28, 2017 | 10:35 AM
txazguy's Avatar
txazguy
Unhappy Tire Size question....
This has probably been asked & answered countless times but I can't find the answer in some of these threads.
I have a stock height '15 FX4 w/ tow & camper pkg....factory tires are 275/70-18.
What are some of the largest sizes you guys have installed without any rubbing?
Old Jun 28, 2017 | 11:59 AM
Sir Kayakalot's Avatar
Sir Kayakalot
35/12.50/18 is about the largest you can go without a lift. Some folks will tell you that you can go 37s but I can guarantee you will rub bad if you go off-road with that size.
Old Jun 29, 2017 | 09:23 AM
Astrosfan's Avatar
Astrosfan
Watching, got same truck
Old Jun 29, 2017 | 10:35 AM
Super Duty DJ's Avatar
Super Duty DJ
It seems that 295/70R18 is a very popular no-lift size and some are running 285/75R18, which has a more limited selection of available tires, but is similar in overall dimensions.
Old Jun 29, 2017 | 07:39 PM
txazguy's Avatar
txazguy
Depends on the tire as far as what is available too...I'm looking at the BFG KO2. My supervisor got some on his truck and they look great on it. So far no complaints from him
Old Jun 29, 2017 | 09:34 PM
keithf's Avatar
keithf
Earlier this year I upgraded to a larger size tire - a new set of Toyo Open Country AT2 in LT285/75R18 - they are 34.8" in diameter.
There was no rub in front even at full lock to lock (although I do have an aftermarket bumper) or at the rear when loaded.
Here is a pic with them on - I was testing rub at the rear - I did not drive like that...
Two weeks later I swapped them out under the Toyo 500 mile warranty as they constantly vibrated the truck even after multiple balance attempts by Discount Tire - I think it is the heavier "XT construction" of the larger tire that is required to get the extra 400 lbs of load capacity.
I went back to LT275/70R18 in the same Toyo Open Country AT2 tire - these are the largest size that is not made with the XT construction - and they drive like a dream.
Hth! Keith
Old Jul 5, 2017 | 11:25 AM
txazguy's Avatar
txazguy
For the tires I'm considering (BFG KO2) these are the sizes available...
LT255/55R18
LT255/70R18
LT265/60R18
LT265/65R18
LT265/70R18
LT275/65R18
LT275/70R18
LT285/60R18
LT285/65R18
LT305/65R18
LT325/65R18
34X12.5R18
35X12.5R18
Old Jul 5, 2017 | 12:45 PM
keithf's Avatar
keithf
Only 3 of the tires you list are larger than what you run today, so that narrows your choice.
Best to look at the actual diameter on the mfgr website, or use a tire size comparison tool - I find this one handy - https://tiresize.com/comparison/
Hth.
Old Jul 6, 2017 | 03:21 AM
94ruck's Avatar
94ruck
My 2015 with 35 x 12.5 x 20. No rubbing. Had to tie back the inner wheel liner with a tie wrap. have 20K miles with no issue
Old Oct 10, 2017 | 12:47 AM
txazguy's Avatar
txazguy
You guys have any idea if these wheels will fit with 35" BFG AT KO2?
https://www.discounttire.com/buy-whe...ls-tko/p/47329
Old Oct 10, 2017 | 12:28 PM
jeremy50's Avatar
jeremy50
I have a 2014 Platinum with 20 inch rims. I've been told from a friend managing at Bell Tire that I can go with 295/65/20's in the Toyo ATII. They run a little "smaller" by nature of the design. I was also told by almost every shop I called that I could run 285/70/20s all day long. No level. Stock truck.
I've heard that the KO2's don't hold up well to the weight of heavy trucks. Debating those or the Toyo ATII's my self.
Old Oct 10, 2017 | 12:35 PM
txazguy's Avatar
txazguy
Discount told me that the KO2s were just redesigned....they now have a 10 ply sidewall so they should be on par with everything else on the market
Old Oct 10, 2017 | 07:04 PM
Randy_270's Avatar
Randy_270
No such thing as a 10 ply side wall on radial pick up truck tires. They'll be 2-3 ply side walls with probably 5-6 tread plys depending on the size and load rating.
As for your question, 325/65r18s on stock rims rub radius arms so im going with 285/75r18 Goodyear Duratracs when they become available
skswayze
Mar 6, 2010 12:09 PM
rangermike
Nov 26, 2008 08:33 PM
FireHazard
Feb 1, 2004 04:23 PM
guruatbol
Aug 6, 2003 12:34 PM
quicker
Mar 20, 2002 09:29 AM
