detergent or non detergent?
Old Jun 28, 2017 | 09:06 AM
Ricardo Chambers's Avatar
Ricardo Chambers
When I went to inspect the valve train, things looked kinda gooey.
Made me think about old time non-detergent oil.
hopefully this engine was running detergent last time it ran...
If I use detergent oil will it break any of this goo loose and clog up any crank oil galleys?
thanks
Old Jun 28, 2017 | 11:07 AM
Connecticut Calvin's Avatar
Connecticut Calvin
So yes when you speak to the classic car buffs that tear engines down to the core and rebuild them after cleaning every crevice you'll learn they typically go detergent all the way. But if your engine has never had detergent and you run detergent oil there is a good chance something will get loosened up and plugged somewhere creating all kinds of problems. Oddly enough you point to an obvious issue. Everything is gunky. That gunk can come loose even with non-detergent oil. I'd keep it as-is unless you're willing to do a teardown and clean it thoroughly IMHO.
Old Jun 28, 2017 | 08:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The engine below was apparently swapped from non-detergent to detergent when detergent oils came out. It had never been opened before we took it out of service. There were no problems with oil pressure, clogging, or spun bearings with it in this condition. One cylinder lost compression so it was replaced. No amount of detergent on earth could break up this goo.
fightlivefree
Aug 31, 2014 08:53 PM
daveya48187
1983 - 2012 Ranger & B-Series
May 1, 2013 01:19 AM
WALFORD'S 56
Aug 18, 2010 10:04 AM
FERacing66
Oil & Lubrication
Apr 1, 2004 11:52 AM
hp11
Mar 7, 2004 09:50 AM
