Modular V10 (6.8l)
Head removal 6.8 procedure
Old Jun 27, 2017 | 10:39 AM
justin richter's Avatar
justin richter
I have a 2000 ex, v10 motor.. about 250k on miles.. I have transmission out getting repaired , and so in the meantime , I'm going to take off the heads and get them redone.. I'm trying to find a step by step procedure to take them off... I've Googled and researched.. any help or websites are appreciated
Old Jun 29, 2017 | 10:11 AM
Im50fast's Avatar
Im50fast
no offense intended but if you can't wing it then this job is probably not in your skill level
Old Jul 1, 2017 | 03:51 PM
maticuno's Avatar
maticuno
Get a Haynes service manual, normally stocked at Vatozone. I was able to do a head rebuild on an old Toyota MR2 following the step by steps in that.
Old Jul 1, 2017 | 11:49 PM
Sam I Am's Avatar
Sam I Am
Basically, you take everything off the front of the engine to access the timing cover which is literally the whole front of the engine and remove the timing cover. Then start at the top and work your way down, air filter, throttle body, wiring, intake, etc.
This is one of those jobs that is $100 in parts and $1000 in labor. "But while you're in there" you might as well replace the water pump, spark plugs & coil boots, vacuum hoses, accessory belt, timing chain & gear set, cam chain guides & tensioners, etc. and of course every gasket along the way.
And if you are putting that much work into it, of course you will want to replace the oil pump, oil pan gasket, rear main seal, oil cooler / filter assembly gasket, etc.
Ready for a longblock yet?
Old Dec 24, 2017 | 04:52 PM
mrpotatohead's Avatar
mrpotatohead
If you don't want to invest in the service manual then you are risking piston to valve damage if you don't time the cams correctly. These motors are parts intensive. Head gaskets, intake gaskets, timing cover gaskets, front main seal, timing chains, tensioners, 4 new timing chain guides, throttle body adapter O-rings, lower plenum 0-rings, cam gears, cam drive bolts, cam drive bolt washers, all new head bolts etc. Don't spend this kind of money and risk failure.
Adam_Tinkerer
Aerostar
Feb 2, 2016 12:29 AM
chefcharles
Jan 20, 2014 06:22 PM
bigb609
Nov 21, 2011 05:35 AM
Xclimation
Dec 11, 2008 06:26 AM
ceetwarrior
Mar 21, 2005 11:45 AM
