6.2L V8 Discuss the 6.2L V8
Hypothetical
Old Jun 28, 2017 | 11:17 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Originally Posted by Ron94150
Wasn't directed toward you chuck, you just posted while I was typing.
The vehicles you are talking about don't have a final overdrive of .67.
No harm...
Yes, I am old north of 65... been wrenching on cars since I was 13...
Old Jun 28, 2017 | 07:42 PM
Tarster's Avatar
Tarster
Originally Posted by Chuck's First Ford
I never follow ...
and the internet ( folks ) are mostly uninformed.. but offer bad (Poor) advice.
towing heavy 50 percent of the time or mountains often... 4.30
the 6.2L and 3:73 is very capable.
my total rig weight is 17,000 pounds. ( cat scaled )...my truck has 152,000 miles.
April 2017 .. trip,, 1,800 miles in 4 days... south Texas to N.E. Ohio not one issue.
I departed Texas at 101 degrees and arrived in Ohio in 33 degrees... and 6 inches of snow.
I was wondering Chuck, what kind of milage did you see with your rig setup in general? I ask because I have a buddy that tows his 5th around the us quite a bit and he has purchased a 2016 6.7 cclb srw. He recently upgraded his 5th to a triple axel and when he did about 4k round trip from Oregon to somewhere back east he averaged 11.5 with a truck and trailer combined weight of 27,200 when he scaled it.
Not a gas vs diesel question here. Just pondering what milage you get vs what my buddy got recently, plus the fact that the op didn't give more specifications on trailer size and such. Might also give him a better idea of he wants to look at a 6.7 or if regearing his 6.2 would be a better option for him.
Old Jun 29, 2017 | 06:05 AM
dnewton3's Avatar
dnewton3
Originally Posted by '65Ford
Somebody please correct me if I'm wrong...
Torque leaving your engine is multiplied through the tranny gears and axle gears. For simplicity let's say you are currently driving with a tranny gear that has a 1:1 ratio. So the torque leaving the tranny is 1 times that leaving the engine (there is parasitic loss but let's leave that out for simplicity). Then the power goes through the axle. A 3.73 axle gear would multiply your engines torque (430 lb ft at 3800rpms for the new 6.2) and create about 1604 lb ft of torque (again, let's leave out parasitic loss for now). A 4.30 axle would multiply your engines torque by 4.30 and give you about 1849 lb ft of torque. This would be an increase of about 15% torque applied to your rear wheels.
HP is directly related to torque so your hp would increase by 15% also.
You are correct in your assumptions and calculations.
I ignore power ratings generally; that concept (while we all recognize the core intent) is really only torque rated at a particular rpm. Rather than saying "My truck has xxx Ft-Lb at yyyy rpm", it's just a mathematical formula of .... (T x rpm) / 5252. We could just as easily make up a new standard called "toothpaste power" or "elephant power" or "camera power"; as long as we define at what rpm the criteria would measured it, it's all relative.
What moves a vehicle (or makes it resistive to movement) is force. Force is mass x acceleration.
To move the truck forward the "thrust" (measured in pounds of force) needs to be greater than the resistant force of it sitting still. There is static force (a steady state) or dynamic force (acceleration).
Bottom line is this: the quote above (reasonably ignoring the parasitic loss topics) does exactly show how the torque is multiplied.
All you have to do to figure the "force" is divide that rear wheel torque by the diameter of the tire.
Simple HS physics math.
Old Jun 29, 2017 | 08:39 AM
brickman's Avatar
brickman
Sorry guys I didn't think this would spark such a lively debate! The new to us Fifth wheel is a 2011 Open Range 337 rls. While on paper it doesn't weigh that much empty , around 9,000lbs, when loaded up it probably approaches 10,500 plus lbs for cross country touring. We go from Ontario Canada directly south to the Southern U.S across to Arizona & California and then up the west coast and into B.C and return in under a month. This is a journey we do once a year, round trip of 7,000 miles plus many more journeys in Ontario during the rest of the year, the truck is rarely unhitched from the rv. A weekend getaway for us is 600 miles (Ontario is huge). Our previous fifth wheel was a light model with a low profile front. I didn't calculate that wind resistance would be such a factor in the towing but it definitely is. So my concern is the long journey and western mountains with the heavier, loaded up rv and added wind resistance plus larger waste and water tanks, & a full fuel load, could make what was a pleasant experience into a chore. The 15% increase in torque is it correct to say that max 400 ft lbs of torque the 6.2 has now it would increase it by an equivalent of adding 60ft lbs?
Old Jun 29, 2017 | 11:23 AM
Chuck's First Ford
maybe 50 ft lbs... 400 + 50 = 450
diesel is like 800 ??????
as for Lively... that has been going on since the 1940's. maybe the 30's.
I remember the debates in high school Shop class in like 1965...
Gas/diesel/ high gears/low gears/ tall wheels/low wheels.
Old Jun 29, 2017 | 09:53 PM
'65Ford's Avatar
'65Ford
Brickman,
Remember, you asked for how much torque and power would increase. So if you put your truck on a chassis dyno with the 3.73 gears and then again with the 4.30 gears you should measure about a 15% increase in torque and power as measured by the chassis dyno. This is done with the engine at wide open throttle. When pulling a camper, a perhaps better way to look at it is the stress on your engine and tranny will be about 15% less. Though I guess it's okay to think of it as having 15% more engine torque...6 of one...half a dozen of the other....
Old Jun 30, 2017 | 06:15 AM
dnewton3's Avatar
dnewton3
Originally Posted by brickman
... The 15% increase in torque is it correct to say that max 400 ft lbs of torque the 6.2 has now it would increase it by an equivalent of adding 60ft lbs?
Essentially, it would be the equivlant; yes.
We presume you understand that modifying the gears does not alter the engine's ability to produce torque. It's actually modifying the drain-train ability to multiply torque.
Again, what moves the object is force. The formula to determine this "thrust" (force) is taking the available torque at the rear wheel tire surface, and then dividing by the tire radius (the moment arm). Presuming all other things are not changed (engine stays the same, tranny stays the same, tires stay the same), then the change in rear-diff gearing will produce a relative ratio of change. Going from 3.73 to 4.30 is (roughly) equivilant to a 15% torque multiplier.
If you want to think of it as "engine" multiplication, then it would be essentially the same as adding 60 Ft-LB at the engine, but still having the 3.73 gears. If this helps you understand the relative effect, then so be it.
Old Jul 7, 2017 | 07:33 PM
brickman's Avatar
brickman
Thanks everyone for their helpful input. After looking into getting the 4:30 gear set proved difficult to find a shop in my area that could do the work, and looking at how I use the truck, I have decided to order a 2017 F350 SC Lariat dually with 6.7 I can't say enough good things about the 6.2, a superb drivetrain and I hope this 6.7 will be as reliable.
Old Jul 7, 2017 | 11:09 PM
82_F100_300Six's Avatar
82_F100_300Six
Congrats Brickman I'm so glad you are getting a dually they feel like you are on a rail when you drive them.
rwetter
Feb 6, 2010 08:21 PM
V10 Family Truckster
Mar 5, 2008 11:34 AM
7.399
Nov 4, 2006 10:03 PM
Budkole
Nov 24, 2004 01:35 PM
DougD
Jul 24, 2004 04:02 PM
