2007 explorer tpms sensor replacement
Old Jun 26, 2017 | 10:00 PM
baverwolf's Avatar
baverwolf
I have a 2007 explorer that has a couple tpms sensors that need to be replaced. I've decided to go ahead and replace all 4 as I'm getting new tires put on. Mine currently has the band style sensors. I've looked online and found that the stem style sensors are much cheaper than the band style. Can you use the stem style on the wheels if they were originally installed with the band type?? If so, can you use any stem style that is compatible with ford??? Or.. Do some ford vehicles use different sensors than other ford vehicles?
thanks!
Martin97C5LS1
Oct 12, 2010 12:31 PM
zkt
Aug 27, 2010 04:50 PM
Old93junk
Apr 23, 2009 03:55 PM
rontx1
Feb 12, 2008 08:09 AM
