2002 4.0L Idle
Old Jun 26, 2017 | 09:59 PM
air1jpg's Avatar
air1jpg
2002 4.0L Idle
I have a 2002 4.0L 4x4 207k. The idle will now occasionally will fluctuate from `800 rpm to 500rpm at idle while in drive. The fuel filter has just been replaced, could it be a sensor, spark plug, mass airflow sensor, air filter, or spark plug wire issue?
Old Jun 26, 2017 | 10:30 PM
spooktn's Avatar
spooktn
Have you scanned it ??? Is check engine light coming on ???? Could be your Idle Air Sensor in the air intake tube between the MAF and the throttle body. Autozone will scan it with a code reader for free. Or you could buy a ELM scantool and run a free program called forscan on your laptop,,,think they have a smart phone app also.Post codes here and someone will point you in the right direction.
Old Jun 29, 2017 | 08:44 PM
air1jpg's Avatar
air1jpg
No check engine light on, but there could be still codes. The truck is now up at a local mechanic, I will mention the air intake tube sensor if I get a chance. If that sensor is bad, would it throw a code?
87&97Aerostrar
Aerostar
May 3, 2017 09:49 PM
beckman
1997 - 2003 F150
May 17, 2012 11:56 AM
cjfaber
Aerostar
18
Feb 23, 2006 11:42 AM
Tiwan
Aerostar
Jun 15, 2005 09:45 PM
DavidBailey180
Jan 8, 2004 03:41 PM
