Does any one have the small retainer clips for the chrome strip that runs along the windshield above the dash? I need 3 of them. I can't find the buggars anywhere. Thank you kindly. I've seen similar clips but they're larger than these.
Does any one have the small retainer clips for the chrome strip that runs along the windshield above the dash and the front of the dash chrome strips that hide the leading edge of the padded dash?
C0AB-6404439-F .. Instrument Panel Moulding Retainer Clip / Obsolete ~ No Ford dealer ore obsolete parts vendor has any.
the ones for the center of the dash were easy to find on fleabay , the very small ones for the trim at the windshield i still have no luck finding but i look at every swap meet i go to and when i find any i will buy all they have and let everyone on the forum know .
Look at these on page 45. It's pdf. Set the view on 100% and compare what you have to these. There might be something close. https://mrgusa.com/fasteners/
I'll bet its #4322....same era and make. That's a great catalog Crop Duster. I have a second set I was going to send Darrell but, unfortunately, I haven't been able to find my "first" set....still looking.
I wonder if a plastic push rivet will work on these? The head could be trimmed to fit the hollow of the trim piece or trim the head and make a square washer that fits in the trim like the original clip.
possibly but i would rather have the stability and holding power of an all metal clip
Ordered the part from Mr. G's. As you can see it's a little wider at the base so it wouldn't slide into channel. With a little gentle persuasion with pliers it fit just fine.
I was able to squeeze wide part down so it slid into channel no problem
