Yep, the el-cheapos from the drug store and once good aftermarket names have been causing lots of problems since outsourcing everything overseas in recent years. Buy a Motorcraft. Just about everything hanging on a rack these days or that comes in a blister pack, battery cables, vacuum caps, bulbs, you name it - is just trash. Not a bad plan to test it in a pot of boiling water before installation.
Just curious but why do you want to change your thermostat? You might want to test it in boiling water first. Many thermostats that are replaced are really OK and overheating problems lie elsewhere. Just a suggestion.
They come in different Temps. Back then folks ran a summer or winter Thermastadt. I'd suggest a 195 degree. STANT 45479
Do you really run a 195 year-round? That's awful hot for an old-style engine. I would think a 180 would be a winter stat, and the stock stat would be a 160.
The stat was all rusted and so was the housing.. took off intake and cleaned it out to will be putting it back on next day or so..than I can hook up radiator..
Above is correct. My '49 when I bought it ran really warm, H all the time. I pulled the stats and they were 195F, the truck did come from MN. I put in the 160F stats and it ran a little rougher than I liked. I then bought the 180F stats and now it runs better and cleaner, temp gauge stays at 3/4 mark.
Sorry I don't have the MotorCraft number handy, but any Ford dealer should have them on the shelf
They are usually brass so if it is rusted it is cooling system residue and should clean up. I would still test it.
Just go to your local Ford dealer and get MotorCraft parts better in the long run.
Going to a Ford dealer is a waste of time, these thermostats are obsolete and most dealers today claim they have no parts catalogs for anything older than 1980.
The second you mention the year, most of these parts clucks say OBSOLETE whether the part is or not, because they don't want to bother, just "shine you on."
1965: Ford changed the thermostat sizes on most vehicles, what they didn't change in 1965, they did by mid-year 1966.
Originally the flange diameter was 2 1/2" .. but after Ford changed 'em, the flange diameter: 2 1/8."
NAPA has the 2 1/2" flange diameter Y block thermostats (same as 1958/65, some 1966 FE engines), but are not listed in their computers.
So you have to get the parts clucks to look in their paper parts catalogs, usually stashed under the counter.
Ford: A8AZ-8575-D .. 160 degree T/Stat (Motorcraft RT-16) / Obsolete ~ GREEN SALES has 36 // A8AZ-8575-E .. 180 degree T/Stat (Motorcraft RT-18) / Obsolete ~ GREEN SALES has 64.
Guess I'll have to get it out for a long trip. Oh yea I forgot, gotta get the body back from the body shop first.
Did Y blocks use the same flange size from 53 to 64, including the Lincoln variants?
Napa #6 will work, there's a thread over at the Ford Barn discussing this. A big block chrysler or Mopar 440 uses the same size, Mr Gasket 4367 - 180°, brass, made by Robert Shaw. Good choice.
160° stats were spec'd before "permanent" antifreeze came into wide use, when methanol and water was used. I believe they are too cold for efficient operation and especially, burning off sludge and condensation. One thing Y blocks had a problem with before detergent motor oils was sludge buildup and oiling to the valvetrain. I would use a 180° thermostat at minimum, but only a 195° in the wintertime, as it is noticeably hotter for good heater output. Engine wear and sludge buildup is reduced by quite a lot with proper engine running temperature. Y block cylinders have lots of meat on them as a class they are known to have some problems but running hot is not one of them.
This is what I found out about thermostats this spring when I was deciding which T-stat to use.
The Stant tech called me back. Here's the details about their T-stats:
The 160° T-stat starts to open at 160° and is full open at 180°.
The 180° T-stat starts to open at 180° and is full open at 200°.
The 1954 shop manual has two listings in the spec section.
STANDARD: opens at 152 -157°, full open at 177°.
HIGH TEMP: opens at 167-172, full open at 192°.
So I put my old 160 degree T-stat back in as it is closer to the shop manual spec. The 180 T-stat is not fully open until 200 degrees and that is 8* higher than the book calls for with the high temp T-stat.
My Temp gauge points between half and Hot when warmed up.
