Cab Mounts - 66 F100
Old Jun 26, 2017 | 10:57 AM
PaulTMurphy's Avatar
PaulTMurphy
Does anyone know if my totally rusted out cab mounts can be repaired and replaced without taking the whole cab off? Would a good body shop be able to work that magic?
Old Jun 27, 2017 | 08:10 AM
PapaMatt's Avatar
PapaMatt
If you search around, you will find threads where people have replaced the cab mounts without removing the whole cab. Someone else may have one right off the top of there head.
Old Jun 27, 2017 | 12:27 PM
PaulTMurphy
I can't seem to find much with the weak search features on here. If anyone has a thread handy, that would be great.
Old Jun 27, 2017 | 12:46 PM
Crop Duster's Avatar
Crop Duster
If your floor pans are in pretty good shape and the cab mounts haven't completely collapsed you could use the slip on type of mounts like LMC sells. The ones like Dennis Carpenter sells are just like the originals and probably would require removing the cab. In either case it's not a simple easy job and any body shop that took it on would probably charge more than the cost of a rust free cab. The picture is about what it takes to put a set of original style cab mounts on.
Old Jun 27, 2017 | 01:06 PM
svolpone's Avatar
svolpone
Carolina Classics makes real sturdy cab mounts. Give him a call. I don't have his number handy, but you can find it all over this site.
Old Jun 28, 2017 | 02:38 PM
PaulTMurphy
I'm looking at the mounts on the side of the cab, near the back.
Old Jun 29, 2017 | 05:31 AM
Crop Duster
Cab mount
Are you talking about the center cab end braces? If so you can replace them without removing the cab.
Old Jun 29, 2017 | 01:20 PM
PaulTMurphy
Actually, on second look. the RH front mount and both end braces are rusted out. It makes me wonder how the cab is even staying on the truck at all.
Old Jun 29, 2017 | 04:54 PM
g4g2g7's Avatar
g4g2g7
if you look closely you'll see the "end braces" (aka floor or cab supports) don't have anything to do with holding the cab on the frame. The cab is bolted to the frame at the front two cab mounts (the new shiny metal in the post above) and ten two bolts at the very back of the cab, which rarely ever rust out to the point they need replaced. If only one front cab mount on your truck is hosed, then it's likely you still have the other 3 bolts securing it to the frame.
Old Jun 29, 2017 | 05:39 PM
PaulTMurphy
Very good to know that the cab is secure, if not a little (lot) squeaky.
87notcher
20
Feb 23, 2017 10:50 PM
64shrtbed
Mar 6, 2008 01:26 PM
olbud
Jan 4, 2008 01:47 AM
redf1001962
Sep 9, 2005 08:53 PM
