Debate on fox shocks
Now there was was a few guys in this fb group that claim for trucks these size with larger tires or even a slight lift that fox 2.5 coilovers with resi are the way to go.
I get they are a larger shock but I don't see how they would improve the ride quality of these trucks enough to justify the exta $
so I bring this topic to you guys, who are more seasoned and wise. What say you guys? Why would you choose the 2.0 over the 2.5 or vice versa?
I didn't get coil overs. Just the shocks.
So the 2.0s and 2.5s ride the same in the street with bumps etc but off road like dirt roads and such I need 2.5s?
whats the difference between running them as coil over vs non coilover?
Coil overs: Offer a superior solution, better ride, better handling, because it contains the shock and the coil spring inside the same envelope and solves slide loading and thrust issues. That said application becomes a challenge and for that reason you do not see it so often. Trying to fit it in at 2 or 4 corners of a car is not easy, the the issues of dealing with shock travel and spring travel. On big truck etc much more room to play.
Reservoirs: Looks cool, but needed as much as taking your accordion on the deer hunt. Work great to keep the oil cool on the Baja 1000, but for asphalt driving not needed and certainly not worth the expense...but sure looks KOOL!
Fox shocks: Became the darling of the offroad crowd and has spilled over into the retail truck market. I am very familiar with them going back 20 years in my my off road days. Good shock, in fact GREAT and some if not all of them are rebuildable, great plus if seeing time well beyond the curb.
The real question you have to ask yourself is do you want to rebuild your own shocks and is it worth the coin to have a cool racing shock under the fender. If it is then by all means go for it, they are a good shock and better than OEM, but then IMO just about any shock is better than OEM.
Your coin, your truck
Its okay. I deal with the harsh bumps my thing is if all I'm doing is hunting and going down dirt roads etc would I regret not getting 2.5s are they that big of a difference or will 2.0s be enough?
With all of that said, I personally think you'd be happy with 2.0s or 2.0 with reservoirs. They will both ride amazing over stock (or any monotube shock like the procomps, ranchos, etc.). They aren't the silver bullet to all of a sudden make your 8000 lbs truck ride like a 3500 lbs caddy. But they still put a smile on my face every time I drive. If you offroad for longer than 30 minutes to get to your blinds or whatever, I'd invest in the reservoirs. If you are just putting out in the fields or driving down fire roads, then 2.0s are perfect for you. Facebook is great to get some info, but a lot of those guys are yahoos with too much money, so don't listen to everything you read
Reservoirs, for mall crawling I totally agree. Although I can tell you the last time I towed my toy hauler the rears were too hot to touch the reservoirs. I know I would have lost dampening ability back there if I didn't have them. Were they needed? Nah, I would have been fine without them. But I would've been fine towing my trailer with a clapped out 1999 Ford F250 gasser...I didn't buy this expensive truck to just be fine, I went above and beyond what I needed so I know that I'll always have "more than enough" no matter what I run into. I do the same for my suspension as well.
You'll be fine with 2.0s. I have 2.5s because I like to go 50-60 mph out in the desert. They make a HUGE difference there, but on the street they are just about the same. If you have to travel 20-30 mins on washboard or rough roads, the reservoirs will make a difference. You wouldn't know you were missing them unless you did a back to back comparison. But shocks without reservoirs will heat up really fast and you'll lose quite a bit of dampening ability. Put your hand on a shock after a 30 minute drive on the pavement and you'll feel the heat. Imagine it working 500x harder. Reservoirs arent just for looks...well, Im sure there's some mall crawlers out there that have em for looks. But there's very real, tangible bonus to having them.
Coilovers, while you are certainly correct in that they inherently perform better on the same plane, the real reason they are coveted in offroad trucks is that it leaves you room for a second shock or a bypass shock. Giving you better ability to have low and high speed compression and rebound, and of course better heat dissipation. You can also use a collar to have dual or even triple rate springs that you can easily adjust/remove/replace for the terrain at hand.
If you want to run your coilovers with the BDS shock still installed in the front you would need to do some revalving. At that point, I'd probably just run the coilover in the front by itself.
But, if you keep the coilover and the extra shock up front, the ride will change a little bit. Unless you get your new coilover valved to run a double shock setup.
"built to get you there, engineered to get you back"
