Hello I have a 1993 Ford F-250 with a 7.3 nonturbo with a manual transmission. My tach has not worked since I bought it. When I start the truck up it works but then it slowly starts jumping around and then the needle goes all the way down. When I rev the engine up so far it comes up a little but no where near where it needs to be. Do I need a new tach sensor? I tried the one off my 1993 f-250 7.3 with a turbo manual transmission it threaded in but the plug would not plugin to the plug in the truck. Are the plugs different for the 7.3s with a turbo?
If you determine the connectors really are different, just splice in the connector from the faulty sensor. I don't think polarity even matters. Make sure to insulate the splices well, as stray signals can throw off the signal to the tach.
But it's more likely just a case of a bent or misaligned terminal.
The first picture is the connector off the 7.3 non turbo the second picture is the connector off the 7.3 turbo.
These tach sensors are so simple, often problems can be cured by removing the sensor and cleaning up the business end and reinstall. They pick up a lot of debris over the years (I believe they are magnetic?) and cleaning is many times the cure.
There's a couple of links in the FAQ to some simple ideas of making a new sensor, but like said above, you can just splice on the proper connector.
Will splice the proper connector on. I tried cleaning it it worked great for a whole 45 seconds. Ordered a new one should be here Thursday.
