Cheap Tach Sensor Replacement
Old Jan 23, 2014 | 10:02 PM
apt403's Avatar
apt403
The tach's been burned out in my truck for as long as I've had it - Always checked the trucks at the boneyard, but they either had a dead sensor as well or were never fitted with one in the first place. I didn't want to eat the ~$70 cost of the OEM part, and didn't want to go through the hassle of wiring an aftermarket sensor that runs off the alternator/harmonic balancer, etc. I found a thread a while back on another forum that states a Chevy Cavalier crank position sensor would work in it's place. $18 from O'Reiley's.
Grabbed a 3/4-16 NF die, scribed a line to know how far to thread it by comparing it with the old sensor, and soldered the old connector to it. Lo and behold, that big gauge that's always taken up space in my dash cluster now does something. I puked in my mouth a little asking the parts counter guy for a GM part, but I took it as the taste of those Hamiltons that are still in my pocket.
The result:
I know, nothing too extraordinary. I did a little bit of Googling while looking for some more info and couldn't find anyone on here that had done it, and I've now increased the total number of pictures of the swap on the internet by 33%.
Next on the list of things to do tonight: 1) Build a new glow plug harness because the spade connector on one of the plugs came loose and grounded itself on the driver's side valve cover. Melting insulation generates quite a bit of smoke. 2) Take apart my fuel filter housing to replace the o-rings.
Have a good one.
Old Jan 23, 2014 | 10:10 PM
RacinNdrummin's Avatar
RacinNdrummin
Innovative man!
Old Jan 23, 2014 | 10:21 PM
apt403's Avatar
apt403
Thanks, man. That means a lot coming from the only guy I've seen actually put ARP studs to the test. The only question that's in my head when you get that S366 in is whether the clouds will part, in addition to the supersonic boom created when the engine fires for the first time. I'm pretty much undecided, but I'm sure I'll be able to see it from Olympia!
Old Jan 24, 2014 | 10:38 AM
Dark Horse's Avatar
Dark Horse
I don't know if you have seen them but here are 2 threads that are related:
https://www.ford-trucks.com/forums/1...ital-tach.html
https://www.ford-trucks.com/forums/1...er-sender.html
I have most of the parts to build the tach I plan to add some other sensors and a data logger
Mark
Old Jan 24, 2014 | 11:01 AM
apt403's Avatar
apt403
Thanks for the links, I hadn't come across them before. I like the idea of using the original sensor body, cool stuff.
That Arduino's got me thinking.. Can't believe I hadn't thought of it before, but that would be the perfect way to get a custom dash built! I've been mulling the idea of of replacing all the factory idiot lights around in my head, but hadn't really thought of a way to do it. The Arduino is perfect! And it could be a pretty slick install, too. I like programming the chip on the Uno, then moving it over to a breadboard. Only takes a few $$ worth of components to get one of those running as long as USB isn't important. Hmm.. You've given me something interesting to ponder on the way to work...
Old Jan 24, 2014 | 12:07 PM
Dark Horse's Avatar
Dark Horse
I have added this data-logger:
https://www.adafruit.com/product/1141
with a little programming and an SD card you could keep a running tab on pressures, temperatures and voltages any where on the truck I still have to buy the sensors and install and do the programming.
Mark
Old Aug 13, 2014 | 12:52 PM
Lance Amatulli's Avatar
Lance Amatulli
Talking Cavalier sending unit.
Hey quick note you can use a input or output speed sensor from a Ford 5R55 transmission with a little grinding with a scruffy pad on a angle air grinder. Remove the bolt lug and o ring grove size it to fit and depth. Did it with one from local transmission shop. Cost for a used one zero. Plus you can save your vomit. LOL
Old Aug 13, 2014 | 01:44 PM
Lance Amatulli
5R55 turbine speed sensor installed
Old Feb 27, 2015 | 08:56 PM
1972RedNeck's Avatar
1972RedNeck
The result:
Wait, so you just thread the plastic?
Old Feb 28, 2015 | 07:58 AM
typefour's Avatar
typefour
Almost any mag pickup will work for this, I made up a couple a few years back for spares and now cant find the dang things. The GM sensor you used is same unit used on my FI conversion on the sandrail, Adapted one to a mulch grinder for an old guy that couldnt bear to pay the oem 200 for a flywheel sensor. Salesman was dissing it saying it wont be durable, or accurate, nothing is durable when a limb peels it off,lol. Been working for him for 5 yrs, same one, smaller target for the sticks and other things
Old Feb 28, 2015 | 08:32 AM
1972RedNeck
So just cut the threads in the plastic?
Old Feb 28, 2015 | 09:53 AM
Chevy_Eater's Avatar
Chevy_Eater
Here's more:
Guide: DIY Tachometer Sender
fordtrucksforever
Jun 24, 2016 05:08 AM
rhkcommander959
21
Jan 10, 2012 08:34 PM
nse1355
Mar 3, 2011 02:00 PM
fast70
Feb 8, 2010 09:12 AM
1995sho
Sep 10, 2007 09:56 AM
