Need help this line is leaking awfully bad, I believe it to be the feed(not the return). Any help would be great. Looking for line name and possible ford part #? I used a 5/8 open wrench on it, removed and cleaned best I could.still leaking.. arrow point at line is 5/8 wrench. Is it the return or feed, any one have a part #?
ford f-250, 1968, 360 v8. looks original. that fitting is on the gear box I believe, steering shaft, like the pic say I used a 5/8 wrench, it the larger of the 2 there?
So its the return?
Bendix P/S: 1966/68 F100/250 2WD; 1969 F100/250 2WD before serial number D96,001.
C7TZ-3A719-J .. P/S Pressure Hose-Use with Bendix P/S / Obsolete ~ 7 available NOS
1967 F100/250 352 2WD; 1968 F100/250 360/390 2WD; 1969 F100/250 360/390 2WD before serial number D96,001.
P/S pressure hose threads onto the pump on one end, threads onto the gearbox on the other end.
------------------------------------------------------------------------------------------------------------- C6TZ-3A713-B .. P/S Return Hose-Use with Bendix P/S / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1966/67 F100/250 352 2WD; 1968 F100/250 360/390 2WD; 1969 F100/250 360/390 2WD before serial number D96,001.
P/S return hose clamps onto the pump on one end, threads onto the gearbox on the other end.
Return hose has a rubber hose swagged onto the metal tube on the pump end.
The rubber hose cracks where the clamp is located. Sometimes you can cut the cracked portion of the rubber hose off, then re-clamp the hose onto the pump.
Thx on the info. I will raise it up and do that.
So was the gearbox replaced? I don't know. I will ask the shop that's gonna do the brakes all around on it. If it's ok.
Your truck may be a '68 but, that's a Saginaw PS gearbox.
Geez Louise, I suspected something like this after I looked at the sector shaft cover. But the OP said in post #1 looks original, so I didn't question it.
BOTH P/S hoses I listed are WRONG .. because they are for BENDIX P/S!
Bendix P/S: 1966/68 F100/250 2WD; 1969 F250 2WD before serial number D96,001.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001, 1970/79 F100/250 2WD & F350.
