Motor swap question
Old Jun 24, 2017 | 12:58 AM
Evans88's Avatar
Evans88
Motor swap question
Hey all.
i got an old 85 302 HO sitting in my shop that is about to go for a rebuild. I wouldn't mind building it up to suit my 94 f150 that has a tired old 5.0 in it already. Will this swap be pretty straight forward? Anything I should know?
Thanks in advance!
Old Jun 24, 2017 | 05:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Are you just swapping out the long block? Should just be a remove and replace. Just make sure you use the HO firing order.
Old Jun 24, 2017 | 08:14 AM
'89F2urd's Avatar
'89F2urd
It is straight forward, just use all of your efi top end on the old long block and match firing order as said above.
If you have the money, get a 347 rotating assembly. Building a 302 has yielded disappointment many times.
Old Jun 24, 2017 | 01:08 PM
Evans88's Avatar
Evans88
So the blocks are essentially the same. i would like to get a slightly more aggressive cam for it, as long as it matches the HO block instead of the f150 block it should be good?
I will look into stroker kits as well but the budget for this isn't huge.
Thanks both of you!
Old Jun 24, 2017 | 02:26 PM
My4Fordtrucks
I guess the engine was out of a Mustang or maybe a Lincoln? The blocks should be exactly the same externally. The cam choice depends on whether the block is already set up for a roller or flat tappet cam. You can put a roller cam in a flat tappet block but it is more expensive.
Old Jun 24, 2017 | 02:29 PM
Evans88's Avatar
Evans88
It was out of a mustang according to the fella I bought it from. I've already taken the intake and heads off. It's definitely a roller cam.
Old Jun 24, 2017 | 02:44 PM
Briansshop's Avatar
Briansshop
85 was the first year for the roller cam in the Mustangs. The cam gear on your truck distributor is not compatible with a roller cam.
Old Jun 24, 2017 | 02:46 PM
Evans88's Avatar
Evans88
So I would need a distributor from that year of mustang as well then?
Old Jun 24, 2017 | 02:56 PM
Briansshop's Avatar
Briansshop
No 85 Mustang was carbed. 86 and up Mustangs were EFI.
Old Jun 24, 2017 | 02:59 PM
Evans88's Avatar
Evans88
Or can I just replace the gear on the f150 distributor?
Old Jun 24, 2017 | 03:26 PM
Briansshop's Avatar
Briansshop
Yes,can replace gear
Old Jun 24, 2017 | 04:23 PM
Evans88's Avatar
Evans88
Awesome that will make things a lot easier. Thanks for so much info!
Old Jun 24, 2017 | 05:21 PM
My4Fordtrucks
If you are keeping the speed density EFI make sure you don't go crazy with your cam choice. They need to get along with each other.
Old Jun 24, 2017 | 05:56 PM
Evans88's Avatar
Evans88
Fortunately the truck already has mass air
Old Jun 24, 2017 | 08:54 PM
Conanski's Avatar
Conanski
All '92+ 5.0 truck motors got roller cams so use the distributor from your truck.
All "94+ truck motors used the HO firing order.
This HO motor already has more cam than your truck motor did.
