charging prob
Old 06-23-2017, 01:51 PM
rustyoldford's Avatar
rustyoldford
rustyoldford is offline
charging prob
earlier this year had dead battery after sitting for a week. 5 year old battery so bought new one
battery still goes dead randomly (overnight), instead of playing radio for a few minutes after key off, dash displays "system off to conserve power"
ran it thru local repair place (ex ford dealer) nothing found. Voltage 14v at 1800 rpm, lights on"
STILL goes dead randomly
I admit defeat, suggestions
Old 06-23-2017, 07:37 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,725 Likes on 1,395 Posts
Do the test below. Even with all this high tech stuff on these trucks, this test still works. Only difference, you will have to set it up and wait about 45 minutes before observing the light. The later trucks do have a lot of stuff that does stay awake and draws current for that time period so make sure everything is off, the doors are shut, the hood light is disconnected, and then wait 45 minutes and then see if you have a bright light. If you do you have a drain somewhere.
Old 06-24-2017, 09:23 AM
alloro's Avatar
alloro
alloro is online now
Received 4,207 Likes on 2,450 Posts
Yes one, tell us what the vehicle is.
Old 06-24-2017, 10:31 AM
Franklin2's Avatar
Franklin2
I guessed it was the 2012 f150
Old 06-25-2017, 06:21 PM
rustyoldford
I will try that.
may try an ampmeter also. I assume the remote, the alarm, the radio clock and ? all draw something.
But is intermittent,
Old 06-26-2017, 01:04 PM
Franklin2's Avatar
Franklin2
I will try that.
Your truck will draw a lot for the first approx 45 minutes. After that, you should not have over 70ma or .07 amps draw.
Old 06-26-2017, 03:27 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Post
earlier this year had dead battery after sitting for a week. 5 year old battery so bought new one battery still goes dead randomly (overnight), instead of playing radio for a few minutes after key off, dash displays "system off to conserve power"
You have the FORD BMS System on the truck.
Reference here- https://www.ford-trucks.com/forums/1...y-warning.html
Old 11-03-2017, 09:46 AM
rustyoldford
BMS, I know what bs is, but whats the m for
autozonk says 6 month old battery is a little weak, but not warrantyable.
my voltmeter still says 14.2 running, but 12.1 when you shut it off. 11.5 in the morning.
i still vote battery, but will try a bms charge.
guy at autozonk says alternator only replaces starting juice, does NOT CHARGE BATTERY
NEED A NEW AUTOPARTS !!!!!!!!!
Old 11-03-2017, 10:15 AM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Unhappy
I guess you didn't read the Referring URL I gave.
Originally Posted by DIYiT
'm just going to have to have the battery tested when I'm home over Christmas. I had 10+ hrs of driving to get up here to ND on the interstate, plus plenty of driving around the area here with very few short trips. The battery should be charging just fine.
Originally Posted by gDMJoe
Depends upon whether or not you had the charger's -(negative) lead directly connected to the -(negative) post of the battery. If so ... Then YES.
There's also a FoMoCo dealership service re-set available ...
BMS reset procedure with Ford "Diagnostic Engineering Tool":
Go to Gen Diagnostics and select Module ID to 726 (BCM)
Select Service 0X10 and extendedDiagnosticSession, and press "Send Message" button
Select Service 0X31
Check "User Defined" box, and type in "201A"
Press "Send Message" button
For future reference, do not connect the -(negative) charge lead to the -(negative) battery post. Connect it to another ground attachment point on the truck. That way, the re-charge will be measured by the BMS hall sensor (very near the negative battery post) and will correctly re-adjust the battery SOC (State Of Charge).
If the dealership's service doesn't have a clue, here is the section in the workshop manual:
When charging the vehicle battery by connecting the charger to the negative battery terminal is necessary, such as when using a combination battery charger and battery tester/analyzer, like the GR 1 190 V3.0 Intelligent Diagnostic Charger, the BCM will not immediately update the battery state of charge. In this instance, after charging, you must carry out the Battery Monitoring System (BMS) Reset using the scan tool. This reset is needed for proper engine off load shedding and to prevent invoking of engine off load shedding earlier than normal.
NOTE: If the reset is not carried out, when the battery is charged by connecting the charger to the negative battery terminal, it takes approximately 8 hours for the BCM to learn the new battery state of charge. During this 8 hour period, the vehicle must be undisturbed, with no doors opened or keyless entry button presses. If the vehicle is used before the BCM is allowed to learn the new battery state of charge, engine off load shedding can still occur and a message may be displayed.
When charging the vehicle battery by connecting the charger to engine or chassis ground, the negative charger clamp must be connected to an unpainted chassis surface or a solid engine component such as a generator mount or engine lifting eye. In this instance, after charging, the BMS Reset is not required. Through this method of charging the BCM will update the battery state of charge during the charging process.
autozonk says 6 month old battery is a little weak, but not warrantyable. my voltmeter still says 14.2 running, but 12.1 when you shut it off. 11.5 in the morning.
AUTOZONE is correct. It is not the job of an ALT to replenish a drained BAT. It may burnout the ALT. This system may also not allow the ALT to recharge to that extent to prevent ALT damage.
You have a parasitic drain on the BAT and it must be diagnosed correctly.
Old 11-03-2017, 02:28 PM
Franklin2's Avatar
Franklin2
I am not sure I agree. The alternator can charge a completely dead battery, it's done all the time when someone is jump started. And I have never seen it ruin a properly operating alternator. I am pretty certain someone that needs a jump is jump started, and then the person helping says "you had better turn it back off or you will burn out your alternator" and they are still left stranded.
You do need to run the car for several hours for it to completely charge the battery, but it should charge it to normal levels eventually.
Old 11-03-2017, 04:45 PM
KULTULZ's Avatar
KULTULZ
KULTULZ is offline
Wink
You mis-understood. The vehicle being discussed is a late model with the charging system controlled by the BCM. FORD has had a lot of problems with the system. If the BAT is in a low state of charge or is getting ready to fail, the computer will not allow the ALT to try and bring it back up.
If you jump one, the BAT has to be brought back up by a proper charge, diagnosed/replaced and the BMS reset or the computer will not acknowledge what has happened.
I would hate to think what one of these computer controlled system BAT would cost.
Now, just to start an argument as it has been fairly quiet around here, the ALT is designed to maintain a proper charge on the BAT, say from starting, running the lights or listening to the radio, It is not designed to bring a low BAT back to spec. It can, but it can also cause ALT failure.
RING!
...and that's how the fight started...
Old 11-03-2017, 07:23 PM
rustyoldford
read the thing about bms.
alternator is 75 amp, means it can support a 75 amp load without draining battery. thats truck, boom box radio, and charge travel trailer battery. thats not in trailer now so i can't check voltage, but was 12,5 when daughter put it in her truck. the joys of fatherhood. should be plenty for charging.
thats the way my mercedes works, my gold wing, n my harley. lets not discuss my first motorcycle, voltage would drop stepping on brake with lights off. hodoka dealer said it was normal. but dont step on brakes with lights on
Old 11-04-2017, 10:42 AM
Franklin2's Avatar
Franklin2
I applaud technology, but the more they put into these vehicles, the more I dislike the newer vehicles. I seems like software engineers who have never worked on a car or truck in their life are designing all these features and junk and just make them more unreliable.
Who in the world has time to let their truck sit for 8 hours undisturbed each time the battery has a problem? I can't believe they write that stuff in there. A business needs to make money, they need their delivery vehicles to work, they do not have time for their truck to sit somewhere for 8 hours while the computer "learns" the new battery state of charge. The whole thing is ridiculous.
Old 11-04-2017, 12:24 PM
rustyoldford
10 amp charger connected to block and +
24 hrs now, and only down to 5amps
Old 11-04-2017, 12:52 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Jump starting is an emergency, get ya home procedure, when ya really get down to it. In a way I agree with the 'zone. Ideally the battery should be placed on an external charger as soon as practicable after a jump. Even better, would be to swap in a charged battery instead of jumping in the first place. There is potential, at least, for mischief during this process. Even battery explosions are not unheard of. Maybe rare, but I don't want to deal with it if I can help it. A battery that has been run down to dead should also be checked. Defective batteries don't do the charging system any favors. And a defective charging system will result in battery problems sooner or later.
In cold weather in particular after a jump you can hear belts and pulleys groaning - that's the alternator protesting loudly. Given that the manufacturers "size" everything these days on the "barely enough and no more" principle it's just good practice to avoid putting the alternator through the wringer. "Let it idle for a half hour" is not the way to go about it. Chargers are inexpensive, alternators and batteries are not, especially if one has to pay someone else for replacement.
Quick Reply: charging prob
