engine transplant
Old Jun 22, 2017 | 10:30 PM
car polisher's Avatar
car polisher
engine transplant
Just pulled 239 Y block and 3spd , installed 351w with C6. My question is with a stock 3.92 rear end will this run down the road on the highway at 70mph ok?
Old Jun 22, 2017 | 11:46 PM
BlueOvalRage's Avatar
BlueOvalRage
The C6 has no overdrive, so if we assume that you'll run a tire in the neighborhood of 27" tall, the engine will be turning about 3400 RPM at 70 MPH. Will it do it? Yes, all day long. Will it be economical to drive any distance that way? Probably not. It will likely suck fuel by the tankerload. And the sound level in the cab would be obnoxious as well. If you're planning to spend a lot of miles on the highway with this truck, then I would suggest either looking into an overdrive transmission or going to a numerically lower gear ratio.
Old Jun 23, 2017 | 12:00 AM
EBEAR's Avatar
EBEAR
Tire size is important and what your expectations are " 70mph all day , short bursts , fuel mileage etc. ". There are many rpm calculators available your c6 is a 1 to 1 final ratio so even with 28" tires it will be revving close to 3400 rpm @ 70mph .
Old Jun 23, 2017 | 09:36 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Here's a calculator that will help figure engine RPM.
Engine RPM / Engine Speed Calculator
Old Jun 23, 2017 | 10:42 AM
bigwin56f100's Avatar
bigwin56f100
Without a lock up converter it's going to be worse than the 239 3 speed
bjmayberry2
May 21, 2017 07:04 PM
F100man
Sep 23, 2010 08:40 PM
Sgt Wonderful
25
Jan 2, 2005 09:33 PM
linrick1
Oct 24, 2004 04:36 PM
Rmartens
Aug 21, 2003 10:12 AM
