Need help with this 351m
Old Jun 22, 2017 | 11:17 AM
Landon Henry's Avatar
Landon Henry
It's a 1976 351m in a gran torino it sat 20 years guy I got it from said it was running he washed the engine started running rough so he parked it so I got it and first thing I did was pull the intake and heads let oil sit in cylinder engine looked clean but did find a lifter and a push rod sitting down in the valley push rod wasn't bent no signs of anything bad happening was almost like someone tore it down and left it sitting their when put back together so next day put it all back together got it to turn over would try to start was firing would be so close but wouldn't quit get their engine is getting gas getting fire good compression exhaust isn't plugged up i have no idea what could be causing this and really want to get this going so I can get the body fixed and painted
Old Jun 22, 2017 | 01:07 PM
beartracks's Avatar
beartracks
Check timing. Also could have jumped the timing chain
Old Jun 22, 2017 | 01:49 PM
Landon Henry
It doesn't sound like timing has jumped though and sometimes u turn it over sounds like it's actually running but let off the key it dies
Old Jun 22, 2017 | 02:13 PM
ubereal2's Avatar
ubereal2
Without commas (,) and or periods (.) this is hard to read.
But, did you check all of the other push rods to make sure that the rocker arms are tight? With loose rocker arms, valves won't get opened completely.
If timing is good, make sure firing order is correct. It's getting fuel, but is it flooded? Have you checked to see that you have a good spark?
Unk Bob
Old Jun 22, 2017 | 02:23 PM
CelticOne's Avatar
CelticOne
Regular User
Have you changed the plugs, wires, distributor cap and rotor button? Sounds like water got in there somewhere.
Old Jun 22, 2017 | 03:06 PM
good to doo's Avatar
good to doo
If some one was dumd enough to for get to put a push rod in? check the timing? It could be they got the chain off by a tooth.
Old Jun 23, 2017 | 05:55 PM
Landon Henry
The rocker arms are tight timing chain is in place just got new plugs and wires saw black marks on the edge of distributer cap on the inside replaced that still not doing any better
wfon
Oct 8, 2014 07:45 PM
Timmernator
20
Oct 2, 2010 01:57 PM
0351mike
24
Jul 23, 2008 09:20 AM
welldiver
Nov 13, 2003 10:05 PM
Sam
Dec 15, 1999 07:51 PM
