Stalling when stopping
Old Jun 19, 2017 | 09:07 PM
scarfo's Avatar
scarfo
Hello guys first post and probably not the last, I got a..
1957 f100
y-block 272
4160 four barrel holley carbs
3 speed manual
The truck idles good once warmed up and accelerates fine but once i slow down to go around a corner or stop i have to rev the engine so it doesn't die. no power braking and it has all new spark plugs,wires,coil,distributor. I dont have a tach set up yet so i don't know what RPM it is at. I am thinking its the fuel level in the float bowls? do i need to adjust both? i found this video online.
Thanks!
Old Jun 20, 2017 | 06:37 AM
Tedster9's Avatar
Tedster9
Hey Welcome to FTE
I think this was kind of a typical problem before all the engine controls came about, if the carb and things weren't tuned just so. Check that timing is straight, what's it at now? Float height plays a role in everything so make sure it's correct. Idle mixture setting is important for off idle acceleration and transition.
Old Jun 27, 2017 | 10:08 PM
chetspencer's Avatar
chetspencer
I had the same problem and fixed it by rebuilding my Holley 4 barrel carb. Runs excellent now.
PapaBearYuma
Feb 15, 2017 03:23 AM
6.0Lover
Feb 18, 2015 08:40 PM
2010Iron883
Feb 24, 2011 08:43 PM
redahtamn
May 23, 2009 11:08 PM
packrat56
23
Dec 21, 2005 10:56 AM
