No Accessories come on
My 02 F250 periodically has no acccesories like electric windows, radio, and AC do not work for a minute or so. It has been doing this for awhile and seems to be getting more frequent and I am concerned that it might go out on a trip. Like to see if anyone knows what the most likely culprit could be. It runs OK when this is going on and usually happens on the first start on the day. I was thinking maybe the ignition switch?
John Henley, Alabama
I have heard that the bottom of the key cylinder can wear out and not work as designed in the electrical circuit.
so for me right now, when I turn the truck off, the hey-dummy-you-left-the-lights-on-buzzer fires up - even with absolutely nothing turned on. as soon as I turn something on (still with the key off and taken out), the buzzer turns off, but the accessory doesn't come on, because the key is off.
so if you can't find a relay issue or any bad fuses, consider replacing the key cylinder on the steering column
Where is this relay located? Now and then my windows and radio won't work when I start the truck up. A little tap on the dash gets it working again and it doesn't act up for a while.
1badazz07150
2004 - 2008 F150
13
07-05-2019 09:20 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
12-28-2016 08:09 AM
Toplait
06-17-2015 09:03 PM
