2003 f250 6.0 ac leak
Hello, I just see a fluid by the front passenger tire leak when the diesel is running and ac is on.There was fluid up by both aluminum lines going into a plastic canister in the engine compartment on the passenger side.I couldn't find any cracks in the hoses or aluminum lines..The plastic canister I believe is (AC ACCUMULATOR ) did have a hiss of air when I shut the truck off. I can't see where the clear liquid is coming from. Any ideas?? Just started to leak by the front passenger tire.
The "leak" as you call it sounds to me that it is condensation. Nothing to worry about and is normal in humid areas.
The "hiss" you hear when you shut it off is the pressurized refrigerant going through the orifice tube. The noise stops because the pressures on both sides of the orifice tube equalize, eliminating flow.
cosmicbrian
03-06-2007 09:55 PM
