Ok so we have a 91 f250 460 that keeps idling high. Idles at 1300-1500. When put in gear it is fine. Every part seems to help.
Pulled the codes only onss are for idle to low???
O2 sensor system lean and egr valve not opening.
So far a new iac valve which when you unplug no difference. getting power to it I already checked.
Adjusted the TPS correctly and brand new fuel pressure regulator. New fuel pumps new map sensor, checked the vacuum lines and no more leaks. Put a new computer in but that was because of another issue. The previous owner did loosen the idle screw but that should lower the idle?
Also put a new ECT in.
What happens if you unplug the IAC valve when its running?
No change at all it runs at the same room.
Originally Posted by '89F2urd
I think you have a vacuum leak. Plug throttle body with rags, you should be able to find it rather easily.
Vac leak would explain lean code also....since your egr is not opening either, I'd trace it's vac source first.
I have looked and looked for vacuum leaks and can't find any not sure how else to find any.
All the vacuum lines are brand new. I may be wrong about this but I think the run lean came after the new fpr however I didn't check codes till after adjusting the TPS.
If it runs with the iac unplugged, it must be a vac leak (I thought you said above that you unplugged the iac and it ran)
Not necessarily. The IAC valve could be stuck, and historically was a very common problem on these trucks.
The good news is we can stop worrying about electrical/sensor issues. Your problem is either a stuck IAC valve, or a vacuum leak. First thing I would try is tapping on the IAC valve with a hammer. If there's still no change, remove the IAC valve and verify the plunger inside moves freely.
That is true, could be stuck. A quick blocking of the throttle body will tell if it's vacuum leak or stuck iac. If it stalls, take iac apart. If it doesn't stall, find leak.
My similar truck idled the same. I chased everything. Finally changed the throttle body and it now idles 600-700. I had already changed all the gaskets that could leak on the throttle body prior. So I assume the leak was coming from the throttle shaft itself.
Sorry for the late reply been super busy with other things.
So today stuffed rags in the intake and no change. Started looking and noticed the egr valve is not fully seated on the intake na 1\4in gap. So tried tighten the bolt no luck it is stripped out. Going to fix it with a longer bolt so that we can tighten it. Hopefully this will fix the issue.
Trav
So you stuffed a rag into the intake and it didn't stall? Could be vac leak at egr like you indicated, but it's definitely a vac leak if it didn't stall.
You can spray ether, carb cleaner, or brakleen around the penetrations of the intake in order to isolate it. Also check pcv valve, if it's stuck open it is a gaping leak. Having rags in the intake while spraying helps.
Pcv valve I just replaced. Only thing I see leaking is where the egr valve mounts to the intake.
Trav
