1989 Ford F150 want truck to start instatly
Sorry guys been vusy with work and my ignition cylinder snapped on me. lol got that fixed.
My truck starts good, good fuel pressure and pump primes with first turn of key. Starts up after a few good turn overs.
Im not trying to rev the crap out of it or so any weird ****. And mostly all the parts Ive been putting in are Ford OEM parts besides like my relays and igntion cylinder.
I'm just trying to have a cleaner start, if that makes any sense. Like turns over once maybe twice and fires up clean and idles nice.
Lots of territory between starting normally and starting instantly. Seems to me that you have done all reasonable steps and the truck is starting normally. You may want to check injector spray pattern, possibly a cleaning may make some small change, but I don't think you have a problem.
Ill look into that as well, thanks.
My buddy told me to get a better starter and stronger battery. Might look in to that as well.
Have you checked for fault codes and (correct) fuel pressure? Does it not start the first time you turn the key? If it does start on the first try with good fuel pressure and no fault codes, you must have a lot of disposable money to just be throwing parts at it.
IMO, the OEM stuff you threw in the trash was probably still better than what you replaced it with.
I had the timing WAAYY off on my truck for a minute.
Had it parked at my brother's, due to lack of drivability, so it would sit for weeks. It fired up better than any other vehicle I've driven.... except the timing was f***ed, and would barely move under its own power.
Timing is the controlling of electrons to the ht leads at precise intervals, given piston placement during the combustion cycle. modification of the timing involves alteration of the excitement cycle during operation. Inspect via inductance sensing beacon, to ensure proper timing.
That was awesome
#29
Sorry guys, what I know about trucks and cars is limited to basically what I've needed to fix on the truck.
#30
