Need a front motor mount bracket
Old Jun 16, 2017 | 04:38 PM
GJCAT's Avatar
GJCAT
I need a front motor mount bracket for an F500/600 with a 300 I6 motor. This bolts to the front of the motor and the front crossmember. I found a part # from the industrial parts book and it looks to be the same as the big truck bracket. # F7JL-5019-BA. Anybody got one?
Old Jun 16, 2017 | 05:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I found a part # from the industrial parts book and it looks to be the same as the big truck bracket. # F7JL-5019-BA Anybody got one?
This is a 1997 industrial part number, and it's not for a F500/600, because the 300 wasn't installed in these trucks after 1979.
And, #5019 is a front cross member, it's not related to the engine.
500 and larger series truck 240/300 has an L shaped bracket (#6028) bolted to the timing cover and the front engine support bracket (#6057) that some people call a cross member.
There are rubber insulators located above (#6038 'donut' shaped)) and below (#6039 'donut' shaped) the bracket.
What year is the truck?
Old Jun 16, 2017 | 07:53 PM
GJCAT's Avatar
GJCAT
The motor is going in a 56 COE. So what I`m looking for is the L shaped bracket that bolts to the engine. I can make it work with some fudging. I already have the correct bellhousing with the ears for the rear mounting. There used to be a lot of these trucks in the bone yards but the last scrap drive took care of the older yards around here.
Old Jun 18, 2017 | 10:39 AM
GJCAT's Avatar
GJCAT
NumberDummy, could you get me the full part number of the "L" shaped front bracket. I`m wondering if some dealer might have one stashed?
Old Jun 18, 2017 | 01:46 PM
NumberDummy
NumberDummy, could you get me the full part number of the "L" shaped front bracket. I'm wondering if some dealer might have one stashed?
There are two, upper bracket (L shaped) bolts to the block, then bolts to the lower bracket that bolts to the front engine support bracket (cross member).
C5TZ-6028-B .. 240/300 I-6 Upper Engine Mount Bracket / Obsolete
Applications: 1965 F100/250 4WD / 1965/66 F350 / 1965/79 F500/600 / 1966 F250 4WD
RED TAYLOR FORD in Corning AR has 1 = 870-857-3518.
AL WHITE MOTORS in Manchester TN has 1 = 931-728-9700.
C5TZ-6028-D .. 240/300 I-6 Lower Engine Mount Bracket / Obsolete
Same applications as above (240 I-6 cancelled at the end of the 1974 model run).
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
Old Jun 18, 2017 | 06:45 PM
GJCAT's Avatar
GJCAT
Thanks I`ll call around
Old Jun 19, 2017 | 04:57 AM
GJCAT's Avatar
GJCAT
NumberDummy, One other thing, could you post an illustration of those parts. Thanks for the help.
Old Jun 19, 2017 | 10:26 AM
NumberDummy
Sorry, cannot, computer has a glitch.
Old Jun 20, 2017 | 05:43 PM
JEFFFAFA's Avatar
JEFFFAFA
Googled it. All the way to the left is the same mount pic Ford shows for the B & F500/600...240/300.
Phil Fleming
Oct 1, 2016 03:48 PM
jmooremtb
Jan 23, 2004 07:38 PM
