A/C Clutch always engaged ???
Just noticed that upon start up and idle ac blows ice cold. 5 miles down the road it starts to blow warmer.
Bare with me as ive misplaced my manifold set. I did have a low pressure gauge from a long time ago.
Low pressure was would stay around 40psi then slowly over 5 seconds or so drop down to 20 hold for about 10 second and climb back up. All while just at idle.
That's after i added a can of refrigerant. After the second can it seems to have stabilized at around 40 psi. Which is still a little low for being almost 90* outside.
I know with just one reading its like reading a book and only reading every other page.
Here is my main question. Is the compressor suppose to cycle? I've always been under the impression it does. So i deemed a bad pressure switch possibly right off the bat. After doing a google search i see some are stating that it runs continuously.
The only time in a 15 min span my compressor kicked off is when i turned the control **** to "OFF" or when i unplugged the pressure switch.
Is this right? Seems like i would burn up the compressor...
phurst
33
06-02-2010 12:13 AM
cobramustangboy
07-03-2007 12:43 AM
Tetchy101
06-17-2002 05:31 AM
