I need some experience on this one........
Old Jun 16, 2002 | 02:44 PM
Tetchy101's Avatar
Tetchy101
I replaced my clutch pressure cycle switch because my clutch stopped spinning like normal and was very, very sparatic.....so I troubleshot to the switch. Now the a/c blows, but.... the clutch rotates a lot more than usual seems to be about 10-15 times a min. Is this normal? This doesnt bug me much except for, I have a Carb and not EFI so it revs the engine everytime for the compressor. 85 bronco 5.8, 4brl Holley. On a side note, How hot should engine parts like the A/C compressor get. Mine gets quite warm, not like red HOT.
Tim
Old Jun 16, 2002 | 03:07 PM
mantta's Avatar
mantta
It sounds like you are low on refrigerant. The pressure switch will cycle the clutch off when the suction side of your compressor pressure drops to around 20 psi. It will cycle back on around 40 psi. If your refrigerant charge was good it would not do this.
Old Jun 17, 2002 | 05:31 AM
Saigon's Avatar
Saigon
madscientist
Jun 7, 2020 08:51 PM
granny_rocket
Jul 14, 2014 07:42 AM
b6fischer
May 22, 2014 01:29 PM
FOWL1
1983 - 2012 Ranger & B-Series
Jul 16, 2013 12:23 AM
rpbfixit
Jul 30, 2012 11:20 AM
