Sponsored by: Real Truck
Differential Fluid
Old Jun 15, 2017 | 08:20 PM
3fidty1's Avatar
3fidty1
Differential Fluid
Hey All,
So i just changed the oil in my 08 superduty with valvoline 80-90 with ls.Now im reading that it takes synthetic which i did not buy....will i need to rip the cover off and refill it with the correct.I dont care about fuel economy just reliability.
3LS rear end
Old Jun 15, 2017 | 09:31 PM
Bigpipes 35's Avatar
Bigpipes 35
Originally Posted by 3fidty1
Hey All,
3LS rear end
You will probably need to replace the fluid as its suppose to have 75/140 synthetic in it and not 80/90..
Old Jun 16, 2017 | 07:21 AM
speakerfritz's Avatar
speakerfritz
and check to see if friction modifier is needed
Old Jun 16, 2017 | 07:25 AM
Chuck's First Ford's Avatar
Chuck's First Ford
do it correctly..
as above said.
gears are very costly.
if you are going to work on your own stuff.. LEARN to get the correct information, then purchase the correct stuff. and do the Job ONCE.
CHEAPER that way.
Old Jun 16, 2017 | 10:00 AM
StrokinIT2001's Avatar
StrokinIT2001
Look at your rpo sticker in your glove box or wherever it is to find out what it came with or look on your diff pumpkin an read the tag. Then call ford and ask them that way you'll know just what to put in there
Ford4Life04
2004 - 2008 F150
Jun 16, 2016 08:51 PM
DPDISXR4Ti
Mar 30, 2013 07:56 AM
SuperDoodie
Oct 21, 2011 06:57 PM
crimsontide
Jan 21, 2005 11:45 AM
droff
1997 - 2003 F150
Apr 6, 2004 10:44 PM
