Gearing concerns
Old Jun 15, 2017 | 02:01 PM
Ford77Pickup's Avatar
Ford77Pickup
Gearing concerns
Alriight, so right now my front and rear axles are geared differently. The fronts at 3.50 and the rear at 2.73. The rear is way to high and the truck had no power.
I'm wanting to regear my rear and was gonna do 3.50 to match the front but at the same time, im wondering if 4.10 would be better for my setup. I don't want to regear the front to but if I have to I will. I'm running a 400 and a C6 transmission on 33s (may do 35s in future).
Would I be fine with the 3.50 gearing or should I put in the extra work to do 4.10s. I'll be using the truck for some towing and little highway use if I can. I can do 65 fine on the hwy now. Just figured I'd get some opinions. Thanks
Old Jun 15, 2017 | 06:08 PM
bsraborn's Avatar
bsraborn
Can't speak technically about the re-gearing, but this link might be helpful to determine engine RPMs for highway use. Looks like 65 should be around 2700 rpm.
Reference Manual: Chapter 3: Axles: RPM calculation
Old Jun 15, 2017 | 06:56 PM
Ford77Pickup
Well 4.11 puts me right at 2722 rpm with my 33s and then 2566 rpm when I go to 35s. Guess I'll do the 4.11s. Think it'll make it a little more fun to drive around town too. 👌🼠thanks.
Old Jun 15, 2017 | 07:09 PM
77fummins's Avatar
77fummins
Remember with an auto you will never be fully locked at the torque converter. You may be a few hundred rpm higher than you calculate.
Old Jun 15, 2017 | 07:29 PM
tabascom16's Avatar
tabascom16
With 33s or 35s you will be much happier with 4:11s unless you plan on driving it mostly highway.
3:50s would be OK but not really ideal. I have run 3:50s and 4:11s in Classic Broncos and these era trucks from 33" to 40" tires and the 4:11s are just soo much better for your normal stop and go traffic and getting up to speed quicker. Yes, at highway speed you will be a few hundred RPMs higher, but nothing the engine can't handle.
Old Jun 15, 2017 | 10:44 PM
palmrose2's Avatar
palmrose2
I like 33's and 3.55 with my manual transmission 351M with holley 600cfm carb. I wouldn't go to the effort of changing my front gears unless I knew I was going 35's or better.
Old Jun 16, 2017 | 03:18 PM
Ford77Pickup
I figured rpms would be a little higher. I forgot to mention that I'm goin to an np435 here soon so I'm not too worried. Most of my driving is stop and go or on country roads goin 55 so I'm not too worried. 4.10 should be perfect for what I'll be using it for. Thanks again guys.
Trstrugar
Mar 18, 2017 09:29 PM
leviticus
Oct 22, 2007 07:28 PM
adaman
Jul 4, 2007 05:37 PM
oregonian
1978 - 1996 Big Bronco
Jun 7, 2004 01:24 AM
rogue69
17
May 17, 2003 10:28 AM
