Diode issues can you by pass them
Old Jun 14, 2017 | 01:06 AM
Steven Yingling's Avatar
Steven Yingling
Sorry I am new. I have a 99 7.3 f250.
330xxx miles on it.
Tonight driving home stoped at gas station turned it off went in and came out truck wouldn't start.
No wts no fuel pump noise. Did some looking found out that people where having this issue with the #30 and #24 fuses being blown.
Checked mine where fine found the diode and looked that up and put a jumper wire since I didn't have any diodes with me truck fired right up and ran perfectly.
My queston is can I bypass the diode ?
whats the issues if I do what are the risk. Thanks steven
Old Jun 14, 2017 | 06:03 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Welcome to FTE! What diode is it?
Old Jun 14, 2017 | 11:22 AM
Steven Yingling
It is the diode under the hood in the fuse box number 36 or 37.
Old Jun 14, 2017 | 12:54 PM
Whitey Ford
If the diode is bad, it's possible the pcm relay is defective and shorted, as the diode provides power to the coil in the relay if I remember correctly.
Old Jun 14, 2017 | 06:44 PM
carltonwebb's Avatar
carltonwebb
Just to clarify, are u interchanging the word fuse and diode to describe the same type of device or are you talking about two different types of devices.
There is a pcm diode and there are fuses in that box.
Old Jun 14, 2017 | 08:20 PM
Stebs's Avatar
Stebs
Diodes are protective devices... it would be similar to bypassing a fuse, possibly even worse..
Old Jun 14, 2017 | 09:35 PM
Steven Yingling
Nope it is a diode.
Yes there is fuses and one diode in this box.
The recurch I've done tells me the diode is a one way current fuse to protect the pcm from back feed basically.
So I think in a emergency to jump it to get off the road or home is okay but to completely bypass it isn't a good idea.
Ford sells them in boxes of 2 for 6 bucks a pice so I have three boxes now.
ill post the part number when I get to them so everyone can have it
Old Jun 15, 2017 | 01:06 PM
hydro man 17's Avatar
hydro man 17
" but to completely bypass it isn't a good idea."
Exactly, it s there for a good reason. They don't add parts just to add parts!
StillNotKing
21
Sep 28, 2021 08:19 AM
dangorgas
Jul 13, 2019 02:48 PM
cordonja
1997 - 2003 F150
Dec 24, 2014 11:47 AM
Heimdallsonn
1997 - 2003 F150
May 21, 2014 07:14 AM
wadecamp
Mar 24, 2008 11:04 AM
