4x4 not working
Old Jun 13, 2017 | 07:30 AM
bishopgeer's Avatar
bishopgeer
4x4 not working
Passenger side front wheel won't engage
Old Jun 13, 2017 | 08:53 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
We need way more info on your truck. You'll get better feedback that way.
Old Jun 13, 2017 | 04:33 PM
bishopgeer's Avatar
bishopgeer
ok, it's an 2010 f150 stx 4x4 with the floor shifter for the transfer case. When I shift to 4x4 high or low the passenger side front axle does not operate. What will cause that? I've heard that it could be vacuum related.
Old Jun 14, 2017 | 05:34 AM
tseekins's Avatar
tseekins
Could very well be the vacuum line that goes to the IWE which is your hub.
Old Jun 14, 2017 | 07:52 AM
mueckster's Avatar
mueckster
Vacuum releases the hubs. Jack up and support the front end with stands. Try turning the front wheels with the engine off. Each CV axle should turn when that wheel is spun by hand. If the passenger side axle does not turn, you have a problem with the IWE not releasing vacuum, or a problem with the hub itself.
Old Jun 16, 2017 | 04:50 PM
kjp7290's Avatar
kjp7290
yes, it sounds like an IWE or vacuum line on the RH side. IWE's are very common on these trucks. great advice mueckster!
Old Jun 16, 2017 | 04:56 PM
kjp7290's Avatar
kjp7290
you can also test the 4x4 vacuum system for leaks w a vacuum pump/gauge.
Old Jun 17, 2017 | 09:25 AM
meborder's Avatar
meborder
They don't work that way.
The vacuum keeps them disengaged. If you remove the vacuum lines the hubs will be engaged all the time. Hence, if you do this test with the engine off, the axles will not turn. If they do, then something is broken in the IWE. With the engine running, both axles should free wheel. If they don't, it may point to a vacuum problem.
Old Jun 17, 2017 | 08:39 PM
mueckster's Avatar
mueckster
I know that. And that's, basically, what I said. The OP's problem is a lack of engagement of the passenger side hub. With no vacuum, both sides should be engaging. It could be a vacuum issue, if the vacuum in the hub does not vent to allow the IWE to engage; i.e. pinched/plugged line. Also, if there is an internal problem within the IWE, the splines will not mesh under spring pressure when there is no vacuum.
Old Jun 17, 2017 | 10:20 PM
meborder's Avatar
meborder
I read your post wrong.
My bad. I was reading it as turning the axle with the wheel stationary. The way you said is correct. The axle should turn when you turn the wheel with the engine off.
My bad.
Old Jul 8, 2017 | 02:57 PM
bishopgeer's Avatar
bishopgeer
Smile Repaired
It was the hub. I had to replace it and now I have 4x4. Thanks guys for the advise.
Old Jul 9, 2017 | 08:22 AM
mueckster's Avatar
mueckster
Thanks for the update! Glad you got'r fixed up!
dwq
2009 - 2014 F150
Nov 30, 2018 07:00 AM
gwig
1997 - 2003 F150
Sep 22, 2011 02:19 AM
rhd01
1997 - 2003 F150
Dec 15, 2007 07:03 PM
edwintruck
1997 - 2003 F150
Dec 2, 2004 02:07 PM
vman914
1997 - 2003 F150
Dec 9, 2003 04:01 PM
