Sponsored by: Real Truck
starter issues
Old Jun 11, 2017 | 10:50 PM
msp2010V10's Avatar
msp2010V10
starter issues
hey guys! I have a 2010 F250 V10 4x4. about every 3-4 times when you start the truck....it seems as though the starter "sticks". If I catch it and shut it off and then turn the key right back it fires up and does not stick. Its as if the gear is staying kicked out into the flywheel. Are we thinking the starter itself? I'm thinking starter...but looking for input before I crawl under it.
thanks in advance
Old Jun 12, 2017 | 08:19 AM
Mike1's Avatar
Mike1
Well, considering I just went through this with mine, more than likely it's the solenoid sticking, it probably has rust buildup inside not allowing it to slip back after starting. Unfortunately for me, I didn't realize the starter was making the racket until I climbed out of the truck, but by that time, I had toasted the starter. I wouldn't take a chance, it could eat the ring gear up pretty quickly if it stays engaged.
WaveyDavey1980
Apr 18, 2019 09:31 PM
MikeTexas3878
4 Cylinder Engines
Aug 18, 2017 09:05 AM
Mike in Ohio
Apr 28, 2015 10:10 PM
BigBadPowerstrok
Aug 20, 2007 07:07 PM
gingerbreadmaniac
Aug 26, 2005 05:14 PM
