No oil?
Old Jun 11, 2017 | 06:57 PM
Bearded Rabbit's Avatar
Bearded Rabbit
No oil?
I Knew a guy with an 83 f250. traded him an 84 302 thst didnt match up to my 83 f150 for his 83 300 ( which is what mone originaly had) i pulled valve cover and all looked fine. pulled oil pan and all looked fine. installed it in the truck and added 5 quarts of new motor oil. its been sitting 8 days now, and no oil registers on the dip stick. I have no idea whats going on, thoughts?
Old Jun 11, 2017 | 08:41 PM
kr98664's Avatar
kr98664
I'm assuming you ran the engine after installation?
The reason I ask is a fuel pump can spring a leak and fill the crankcase with fuel. If a lot of fuel gets in there, it will dilute the oil so badly it looks like no oil at all on the dipstick.
I had this happen with a straight 4 Jeep engine once. Also had the oil pressure light flickering because the oil was now so thin. I thought I had lost all oil somehow, and added several quarts but nothing registered. Turns out I was looking at a dipstick showing a severely overfilled crankcase, but mostly fuel, so it was hard to see.
This should be quick to rule out.
Old Jun 11, 2017 | 09:14 PM
rowdyredneck's Avatar
rowdyredneck
Are you sure it has the correct dipstick? Maybe its too short. Had you checked the oil before?
Realslowww
Apr 6, 2015 01:16 AM
Redneckmorton
15
Jun 24, 2012 07:01 AM
powerstroker04
Aug 29, 2005 05:54 PM
catalina38
Nov 4, 2004 09:38 PM
busybee
Sep 19, 2004 08:52 PM
