Okay me and the family where headed up camping for the weekend and as we where coming down a steep grade I hit a bump and my truck shut down, not a big bump but just a small everyday bump restarted tried to get it to a safe location and it didn't work got it towed into town and replaced my cps, truck took a few cranks and finally started. Shut my good and it bogged down, went to pop the hood and slammed my driver door and my truck shut down. Started the truck and did it again and it would either bogg down or completely shut off. Has anyone seen this before I don't know where to start I am guessing it's a short issue but not sure any help would be great so I don't have to bring it to the stealership about 200 miles from home. My tools are limited as I'm up in the mountains
At this point its just guessing, but saying that why not go around and see if any wires are loose. It was probably working loose before the bump, the bump just finished the job.
I am pretty sure I got it seated properly but not 100% what's weird is I can always just restart the truck but that is something I will look into it for sure. Finally started finding similar issues and they came down to the same chip was not seated properly or it was dusty but I have no idea. This is the first chip I have ever ran
You have a loose electrical connection...I think that is agreed on by all. You need to check your exterior connection to the UVCH (x2), the big plug on the driver's side valve cover, and that your chip is seated properly (and staying that way). Think back to what all you had apart to do the work (if you did it). Something didn't get snugged up.
Yeah I did the work, there is only the uvch plugs, 42 pin connector, 104 pin pcm connector, pcm and the chip. But it gives me somewhere to start thanks, any other help is greatly appreciated I will check some things in the morning and hope it works. Our friend picked us and all our gear up and brought us to the camping area so I will drive down in the morning and check
Only other input is wiring. It is old, and can be brittle anywhere it is exposed to heat. You might have a intermittent break in a wire (open) after unplugging things and moving wiring harnesses around when you did the work. If all your connections are tight, you will need a multi-meter for further troubleshooting. Any code reader you can lay your hands on will make things go much faster if it comes to that.
If it were your chip being loose on the PCM, you'd have blown your PCM if it came loose while the engine was running, so I doubt that's the problem since you can restart the engine.
You can blow the PCM even with the engine off but with the ignition key in the "ON" position if you remove or install the chip, so I doubt it's that, even though you should be thorough and eliminate that as a possibility.
Your IDM is in the drivers side fender well. Hood slam and drivers side door slam might affect some kind of compromised electrical connection there.
Thanks guys I will let you know what I find. Hopefully it's not to bad, I thought the idm or cps originally when it first started, until the door slam because it's any slam to the truck that does it
It's an 02. The only thing that looses power is the tach all other lights stay on not sure if it's a power or just the fact the vehicle is shutting off., and it's broke down in silverthorne. I did check the ipr nut and it is present and tight
