Moly Grease/ABS port
I listened to Marv on the grease;
"Use a non-moly lithium-based NLGI #2 grease. The best commonly available is the red Mobil-1 grease."
Timken used Exxon/Mobil Infinitec 152, but it's not available in smaller quantities. I went searching for a more-available grease that was similarly-rated and came up with this Delo greases.
For something readily-available, that's also very good, Mobil 1 Synthetic Grease is at most auto-parts houses.
Anything you use should be lithium-complex-based, and the use of any moly additive is debatable. Timken didn't, probably for a reason.
Pop
Pop
SpringerPop
52
03-21-2016 09:36 AM
