Front end clunk solved!
Old Jun 11, 2017 | 12:15 AM
Singlecoil's Avatar
Singlecoil
We bought a 2005 Excursion about 9 months ago and it has had an occasional clunk in the front end for quite a while. Mainly when turning and either accelerating or going over bumps. The strange thing is that it would sometimes get worse, then get better for a while, then worse, etc. I replaced the sway bar end links and bushings, but that didn't fix it. I had it looked at and my mechanic couldn't find anything wrong, so I took it to a Ford dealer in truck country. They spent a while with it and couldn't find anything until I took them for a test drive and miraculously made it clunk with the mechanic in the truck! They then diagnosed it as a bad leaf spring shackle. Replacing that fixed it! What a difference. The truck just seems rock solid now in a way that it didn't before. I just thought I would pass this along as it wasn't easy to diagnose.
Old Jun 11, 2017 | 01:27 AM
Watcher58's Avatar
Watcher58
Welcome and Thanks. I'll file that tidbit away.
Old Jun 11, 2017 | 01:41 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Singlecoil
... They then diagnosed it as a bad leaf spring shackle. Replacing that fixed it! What a difference. ....
You must have a 4x4, our 2002 2wd has coils up front.
Ours has had a couple of thunks in the front end.
I upgraded the front sway bar and its' bushings with a Helwig so that wasn't the problem.
One thunk occurred going thru dips in turns was the left outer tie rod end.
I've been replacing the tie rod ends one at a time.
There is another thunk going straight over speed bumps which may be the right inner tie rod end (last one).
Old Jun 11, 2017 | 06:39 AM
sccamper's Avatar
sccamper
My 2wd has a clunk in the front when turn sharp and rolling. Like pulling out of a tight parking spot. Tie rods are tight. I've replaced the ball joints and rear bushings on the radius arms. Still there. I think it is going to be the inner bushings of the Ibeams. Just haven't taken the time to go there yet.
Old Jun 12, 2017 | 06:02 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by sccamper
... I think it is going to be the inner bushings of the Ibeams. Just haven't taken the time to go there yet.
So a new right inner tie rod end fixed a 2nd thunk in the front end.
We bought our 2002 with 104k and the front end was making thunks, but it was difficult to pinpoint where.
I replaced the shocks (they were toast), new front sway bar/ends (for towing), trans mount and just finished all the tie rod ends.
The tie rods ends definitely fixed two of the noises.
I think the thunk was difficult to pinpoint because there is still a 3rd.
It makes a soft thunk, but not very often.
The first 2 tie rod end related thunks happened very often.
The radius arm bushings look fine and I was wondering about the ball joints.
I looked at the inner I-beam bushings and one looks not quite centered.
Please let us know how it goes with yours.
Old Aug 17, 2017 | 12:30 AM
R&T Babich's Avatar
R&T Babich
Update: Found the 3rd thunk.
When we bought our Ex there were thunks in the front end.
One of the first things I did was install Hellwig anti-roll bars, rear leaf springs and shocks.
New tie rod ends fixed 2 of the thunks.
The 3rd was being caused by the rear anti-roll bar install.
On the left side I had installed the bar connecting rod to the frame with the bolt facing inward.
The rear leaf spring would hit or rub the end of the bolt causing a thunk that sounded like it was under the driver's seat.
Reversing the bolt to face outward has eliminated the noise.
Weird how the sound traveled thru the frame to seem like it was the front end.
I read another post how someone had a similar issue with a loose rear anti-roll bar mount causing a sound that seemed to be in the front so I checked mine and found the worn bolt end.
jrlaidle
Jul 25, 2017 06:59 PM
tsmall07
Jun 28, 2015 09:47 PM
moomba2002
15
Apr 21, 2014 05:16 AM
nashvegas99
Dec 24, 2012 11:51 AM
shark1979
Mar 2, 2009 10:33 PM
