Help! Receiver hitch install
Old Jun 10, 2017 | 03:50 PM
GuitarJesus's Avatar
GuitarJesus
Hey guys, I'm replacing mu Putnam XDR hitch and while doing the install of my Curt, an existing hole overlaps by about 1/8 inch. Is it ok to elongate the hole in the frame? I'd rather do that than make that much bigger a hole.
thanks in asdvance.
Old Jun 10, 2017 | 04:03 PM
Conanski's Avatar
Conanski
Yes open up the hole in the frame a little.
Old Jun 10, 2017 | 05:47 PM
mrollings53's Avatar
mrollings53
If you are talking about the hole aft of the frame rivet, yes you can elongate it. The hole forward of the rivet looks like it may be too big when you are done.
Old Jun 10, 2017 | 08:51 PM
Diesel_Brad's Avatar
Diesel_Brad
If not supplied I would use Trunion washers or a piece of angle on the top side of the frame that also ties into the rear most bumper bolt
Old Jun 10, 2017 | 10:51 PM
GuitarJesus
It came with all the attaching hardware. That was judt me eyeballing it to see if the pre-existing holes lined up decently. I used a die grinder and made an oval slot
Uni Moe
Jan 20, 2017 09:37 PM
joe84ford
Aug 4, 2016 11:30 AM
YoungMT Hick
Apr 17, 2007 09:37 AM
WVFordTruckMan
1983 - 2012 Ranger & B-Series
May 23, 2006 10:22 PM
SoTX yellow
May 19, 2004 09:49 PM
