baby swamps on a CA emissions split shot engine
Will single shot baby swamps run on a split shot engine with 6 pos chip reburn only? Or does the pcm itself need reburned?
Reason I ask is that I just finished a swap of a 97 split shot engine and ZF5 into my 96 CC SB that had an E4OD. I moved about everything over from the 97 including pcm. I'm not even getting close to firing. Guy at Swamps said it should start without the chip... But the pcm I'm using is for the stock split shots.
Chip will be back next week. Wondering if the chip would do it.
The other question, is should I put my old pcm back in that ran single shots? It was for an auto and now I have a manual. Does it really care?
Or any other things to think about?
Another update: I discovered the underhood harnesses were quite a bit different from my original 96 auto truck and 97 donor. The 97 had CA emissions so that may add to the variation. The underhood harness had different or additional pins at the engine connection, firewall connection and transmission connection.
Swapping the underhood harness from the donor truck made the donor pcm work perfectly and everything else seems to work fine with no check engine light. The manual pcm seems to make it run better all around. I was getting a lopy idle at start up and a slight stumble when slowing for a stop sign when using the auto computer.
papadelogan
13
12-10-2009 08:41 AM
foxracing0934
07-02-2009 05:12 PM
