Fuel gushing out of filler tube when I remove filler cap.
Just got a '96 F-250 crew cab short bed with duel tanks. Filled front tank and put cap back on. Was going to put some in rear tank but as soon as I removed the fuel cap fuel gushed out of filler tube. Check engine light is on now. Got a code P0443. Evaporative Emission System Purge Control Valve Circuit. Is there some kind of check valve in the system that goes bad?
Almost sounds like the fuel from the front tank was returning to the rear tank. Research the switching system and controls for the dual tanks. I had a similar issue with the older system in my '88 F150. My system uses fuel pressure to direct the proper supply and return, where yours should have an electric solenoid valve, I believe. Give that a look, anyway.
DevilsAdvocate
12-27-2016 08:23 PM
76 F250 4X4
11-10-2003 01:00 AM
