Voiding Warranty?
Old Jun 8, 2017 | 04:30 PM
Joshua Hurst's Avatar
Joshua Hurst
Voiding Warranty?
This isn't specific to only 17 Super Duty's, but if a person puts a lift/level on their truck and bigger tires, does it void the warranty? When I asked on Live Chat, they said if the dealer says the aftermarket item caused the failure, it would not be covered? Has anyone ever had any problems with warranty work with a lift? TIA
Old Jun 8, 2017 | 05:19 PM
ERock62's Avatar
ERock62
It's always a touchy situation and also depends on the dealer.
https://en.wikipedia.org/wiki/Magnus...s_Warranty_Act
They need to be able to prove that the modification caused the failure.
I can give you an example coming from having a Tundra. For a couple years the Tundras were prone to steering rack failures regardless of it being lifted or not ($1800 repair). A lot of people had issue with lifted trucks + failed rack being denied warranty repairs at some dealers due to the claim the lift+big tires caused the failure. It really comes down to the dealer and if they care it has modifications. For my truck, I was lucky to have a dealer that installed lifts and did modifications... so any warranty claim was a non-issue.
Old Jun 8, 2017 | 05:22 PM
Desert Don's Avatar
Desert Don
If you lift/level, then have steering/suspension problems......they will NOT warrany that portion of your vehicle! If you lift/ level and have a problem with your electronic engine controls......different story, unless the problem can be traced back to your mods. If you lift/level, and your entertainment/navigation/communication system gives problems, they would have a heck of a time connecting the two. Read your state/federal laws pertaining to warranty, the *BEST* way for *you* to know, rather than rely on internet cowboys.
And, by the way, no vehicle manufacturer is going to warranty aftermarket products. Buy a Jeep and put a Rock Crawler suspension under it, if somethinmg on the suspension breaks, one has to look to the manufacturer of the suspension for warranty, not Jeep (as an example).
So, with this being said, Ford will warranty *their* product, as long as *your* product did not cause the defect. Hope this makes things as clear as mud for you!!
Old Jun 8, 2017 | 08:23 PM
MagicMtnDan's Avatar
MagicMtnDan
Get to know the Magnuson Moss Warranty Act!
SEMA spends a lot of time on this stuff as most of their members are aftermarket product manufacturers. Read up on it and you'll feel a lot better about modifying your cars & trucks.
LMGTFY
cc322
Feb 27, 2006 09:30 PM
Saxon
Apr 8, 2005 04:37 PM
arcticcat
Oct 13, 2003 02:29 PM
clown926
1997 - 2003 F150
Jul 9, 2003 06:31 AM
ryanben
Jun 30, 2003 12:33 PM
