what's the safest, best quality, least invasive, non warranty-messing with, best looking, non ride changing leveling kit for my new platinum super duty
A 1" level on the front is just a spacer for the spring. Not enough to need any adjustment to geometry. Do you want to run stock tires? If so, lower the rear. If you want a little more clearance for larger tires, raise the front a hair. That's my opinion.
sandbags are cheap, don't void warranty, easily removed and they give you a better ride quality with enough of them in the bed
My .02 says the best is to be left alone. If you level it then you'll need to adjust your headlights. Then you will probably break the adjusters (in another thread) which could potentially cost you thousands. LOL.... Jonser5000 is onto something with the sand bags....
