fuel question. What is this?
Old Jun 7, 2017 | 05:26 PM
Rusty 57's Avatar
Rusty 57
Does anyone know what this is? It's screwed on the frame under the cab, the fuel line goes through it. It has two wires, one is grounded to the frame and one goes under the dash.
Just some info. 57 f100 302 with mechanical fuel pump. It makes a ticking noise when the key is in the on position (is this bad?).
Old Jun 7, 2017 | 07:05 PM
Joshua1960's Avatar
Joshua1960
It looks like some sort of fuel filter to me. As for the box with wires around it, maybe it's an induction coil that magnetically filters metal particulates in the fuel? Not sure.
Old Jun 7, 2017 | 07:23 PM
willowbilly3's Avatar
willowbilly3
Ity looks like an electric fuel pump to me.
Old Jun 7, 2017 | 07:36 PM
matthewq4b's Avatar
matthewq4b
That is an electric fuel pump of the Facet type AKA pulse fuel pump. They are used in many Military and Marine applications.
Cube Fuel-Pumps | Motor Components, LLC | Facet Purolator
Old Jun 8, 2017 | 07:04 AM
Rusty 57's Avatar
Rusty 57
I think you maybe correct Matthew.
Should it be making a loud ticking noise?
Old Jun 8, 2017 | 09:39 AM
matthewq4b's Avatar
matthewq4b
Yes, as long as it is ticking it is working and pumping fuel, those Facet pumps are not quiet. When they get near their end of life they will stop ticking/pumping and usually a light rap with the handle of a hammer will get them running again. When they do that it's time to replace it.
Matthew
Old Jun 8, 2017 | 12:25 PM
Rusty 57's Avatar
Rusty 57
Thank you very much for the info.
Texican01
6.7L Power Stroke Diesel
Feb 20, 2017 10:40 AM
chicagodragon
Dec 23, 2009 07:16 PM
RedSkin12B
Flathead V8 & Flathead 6
May 22, 2007 05:48 AM
cbfomoco
Sep 13, 2005 12:41 AM
mike L
Sep 1, 2004 04:23 PM
