VIN decoding
Old Nov 22, 2001 | 08:18 PM
jimmorrison2000's Avatar
jimmorrison2000
Post VIN decoding
Does anyone know where I can find a VIN decoder for a 1990 F150 XLT Lariat Ext. Cab 4X4?
I need to get my VIN decoded so I can get some information to take my truck back to original equipment. here's the VIN if anyone knows where to go or how to decode it. 1FTEX14N5LKB42804
Old Nov 22, 2001 | 10:59 PM
PAUL_2's Avatar
PAUL_2
VIN decoding
You know most of what the VIN will tell you except where the truck was made ...Its got a 5.0L engine , the 5 is a check digit , whatever that means , It was made in Wayne , Michigan , the B42804 is a production sequence number . Other than the rims , tires , bugscreen & rollbar it looks stock , What is it that you want to make stock ?
Old Nov 22, 2001 | 11:05 PM
MustangGT221's Avatar
MustangGT221
VIN decoding
1FTEX14N5LKB42804
1FT-Ford Motor Co, USA- stands for the World Manufacturer Identifier
E-Hydraulic-class E-6,001-7,000lbs GVMR range-Brake system and GVWR
x14-super/crew cab 4x4-Model or line,Series,Chassis, or body type.
N-302 5.0 liter V-8 Ford-Engine,displacement, cylinders,fuel,manfact..
5-check digit for all vehicles
L-year
K-Kansas city:claycomo Michigan-Assembly plant codes
b42804-Production Sequence Number
Hope that helps :-)
Old Nov 22, 2001 | 11:11 PM
MustangGT221
VIN decoding
The truck was made in Kansas city: Claycomo, Michigan...not Wayne Michigan.
Old Nov 23, 2001 | 12:59 AM
PAUL_2's Avatar
PAUL_2
VIN decoding
Sorry for the misinfo on the build location , The Example on the diagram I looked at used L , Which is Wayne , Michigan ...K L Next to one another in the alphabet , I typed in the L location instead of the K location .
Old Nov 23, 2001 | 01:18 PM
jimmorrison2000
VIN decoding
Paul, I was looking mainly at the engine. It has a 5.8L 351 in it and I was about to start on a complete resto. and was hoping that maybe the 5.8L was stock. thanx for your help.
Old Nov 24, 2001 | 12:36 AM
stryder's Avatar
stryder
VIN decoding
