Sulastic Spring Shackles? (All 3 concurrent threads merged)
Received 6,719 Likes
on
Will the rear end squat even more under a load since the Sulastic springs are fully compressed? I haven't looked for numbers that show compressed versus uncompressed heights.
I was debating starting a new thread or keeping everything centralized, but wanted to let you know that Sulastic is offering a FTE discount for those interested in buying their springs. After reviewing Big Truck / Big RV video that ruphianh provided I can say I was impressed. I reached out to Sulastic to see if they would participate in a group buy and was provided that they would love to. They are offering a $30 off coupon code to help make the buying experience better. I am providing links to their product for your needs as well as the coupon code below:
I did inquire about having to grind the hitch and was informed that they improved the design so that there is no longer a need to modify the hitch.
2017+ shackle for ride/comfort
2017+ Heavy Duty shackle For heavier loads
Coupon code for $30 off Sulastic Shocks is sulasticfte
Also, I'm going to edit the initial post to include this info for the group buy.
They said that you no longer need to do this. That was my initial challenge but they re-designed them to fix that.
If using the standard shackle the ride will be more comfortable but you will likely bottom out the shackle when carrying a heavy load as the rubber will be compressed.
Its more dependent on how you use your truck. If your carrying heavy loads more frequently then the HD shackle makes more sense. If you carry heavy loads occasionally then the standard one likely makes more sense.
From what they told me, the HD springs use a harder rubber compound for the shackle, so the ride will be harsher if using the HD springs on the F250/F350 without a load.
Can you not just run the regular duty for good ride and when you run a loaded bed, bottom out the shackle?
