2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Sulastic Spring Shackles? (All 3 concurrent threads merged)
Old 06-19-2017, 10:51 PM
hollapm's Avatar
hollapm
hollapm is offline
Originally Posted by DL222
I have a Bakflip cover, 50 gal aux tank and a B&W that stay in my truck all the time. Witch one would work the best regular or the HD?
I'd give them a call but seeing that you have a B&W you likely tow a fifth wheel on a more regular basis? If so I'd opt for the HD, if not and it's just the auxiliary tank and hitch and occasionally tow a trailer then I'd stick with the regular one. That's my thought but give them a call.
  #32
Old 06-19-2017, 11:41 PM
ruphianh's Avatar
ruphianh
ruphianh is offline
i watched both videos and I didn't catch if he was running the standard or hd shackles. He was on the bump stops with the 5er so maybe standard?
Also, Looks like this will lift the truck another .5" in the rear since the shackles are shorter. Ya?
  #33
Old 06-20-2017, 12:16 AM
ZooDad's Avatar
ZooDad
ZooDad is online now
If you are talking about IronCobra, I spoke to him. His rig is a 450 and he is running the HD version.
  #34
Old 06-20-2017, 12:11 PM
hollapm's Avatar
hollapm
hollapm is offline
I gathered some more information from Sulastic:
When the Sulastic's are originally installed the height of the bed may increase up to 3/4 of an inch. After a few weeks of settling they will even out to the factory height.
When debating on the HD vs the Standard Sulastic Springs, if you are going to be carrying a load over 3/4 of a ton on average, then it's recommended to go to the HD springs. So if you have a hitch/aux tank and its under this weight (which it should be) than the standard one will work just fine
The only difference between the two (standard vs HD) is the rubber compound.
If the rubber were to completely fail the shackle would not separate. The only issue would be metal to metal contact on the shackle.
  #35
Old 06-20-2017, 08:20 PM
theboom's Avatar
theboom
theboom is offline
I would be very interested to see more about this product. Take a 450, lower the air pressure in the tires to a more comfortable level, change the shocks, and put these sulastic springs and you might have a pretty darn nice riding truck while still having the most capable pickup that money can currently buy. Might even be as comfortable as a f150. Most likely not but who know we would have to test it. I would just be curious how the springs would hold up towing the 450's 32,500lbs with over a 4500lb pin weight.
  #36
Old 06-21-2017, 05:48 AM
Chris Crews's Avatar
Chris Crews
Chris Crews is offline
Anyone confirm these raise the rear up at all?
  #37
Old 06-21-2017, 06:10 AM
LiquidSteam's Avatar
LiquidSteam
LiquidSteam is offline
From 2 post previous:
"When the Sulastic's are originally installed the height of the bed may increase up to 3/4 of an inch. After a few weeks of settling they will even out to the factory height."
  #38
Old 06-21-2017, 03:23 PM
Chris Crews
hmmm. Would these even help ride quality unloaded?
  #39
Old 06-21-2017, 03:31 PM
hollapm's Avatar
hollapm
hollapm is offline
Watch the video, but from what I have heard, greatly.
  #40
Old 06-21-2017, 07:39 PM
ruphianh's Avatar
ruphianh
ruphianh is offline
they're shackles, not springs, the raise is due to design of shackle, not any added stiffness to a spring.
  #41
Old 06-28-2017, 01:45 PM
fleming23's Avatar
fleming23
fleming23 is offline
Tried to order a set with the group buy code but they are out of stock and won't add to cart at the moment.
  #42
Old 06-28-2017, 11:33 PM
hollapm's Avatar
hollapm
hollapm is offline
Mine are suppose to arrive on Friday. I'll reach out to them and see when they plan to get more in stock.
  #43
Old 06-29-2017, 05:26 AM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
That's where they make the most noticeable difference.
  #44
Old 06-29-2017, 10:10 AM
hollapm's Avatar
hollapm
hollapm is offline
It looks like Sulastic added it back onto their site. The ran out of attachments for the 2017 Super Duty's (are getting more on Friday) so it was taken down. It's been added back and they should have plenty to fulfill many orders. Let me know if you run into any challenges or reach directly out to them.
  #45
Old 06-29-2017, 10:29 AM
fleming23's Avatar
fleming23
Thanks, although now the group buy code isn't working. Going to try to email them to get the $30 off.
Edit, nevermind. When I logged in with my account it worked. Order placed, thanks again!
Quick Reply: Sulastic Spring Shackles? (All 3 concurrent threads merged)
