increasing payload
Old Jun 5, 2017 | 03:04 PM
jeremy123's Avatar
jeremy123
increasing payload
So I ordered my f250 diesel without properly thinking it through as I know a lot of others did, and was shocked at the 2200 payload sticker. I know I know I should have got the 350 and would have if I realized what the payload would be. It's a done deal now and I love the truck so...
Now, If I want to upgrade to a 5er, can I just add another leaf spring and inflate the tires to 80 (they are rated for 80) and add some air bags, would I then be safe getting a 5er with like a 2k lb pin weight? I understand I will be going way over the 2.2k it is rated for with the passengers, cargo etc, and I will technically be illegal, but would another spring, tire pressure and air bags be safe?
Any other options? I've always had bumper pull campers and never been an issue
Old Jun 5, 2017 | 03:06 PM
wb6anp's Avatar
wb6anp
the 350's also have a heavier rear axle. Unless you have the High capacity tow package.
Old Jun 5, 2017 | 03:13 PM
bikerman5345's Avatar
bikerman5345
You will be fine. The axle under the F250 was the same axle in the F350 for previous gens that had a higher payload. Add the bags and tow. I tow my 5ver with a pin weight of 2500 and its a non issue. The weight to watch is your axle weight and tire load rating. But ultimately that axle can handle much more. There are a lot of threads on this and you will get a lot of differing opinions.
Old Jun 5, 2017 | 05:51 PM
Flyct's Avatar
Flyct
FTE Community Team
I ran into a guy at the Tampa RV show a few months ago who was towing a 14,000 lb Grand Design 337RLS with a F-250. He claimed he had his F-250 legally upgraded to a F-350 payload and added 1,000 more lbs of payload. He said he had the modification done by Tampa Spring Truck Parts - leaf springs helper springs, suspension components, Contact Us Tampa Spring Company,Tampa, Ocala, Lakeland, Bradenton, FL
He said they are one of only a few who can legally do the upgrade and also provided a new Payload label for his truck showing the new payload.
If you call them they should be able to tell you what needs to be done and how much it costs. If you call them please let us know what they say.
1L243
6.7L Power Stroke Diesel
13
Mar 21, 2023 04:02 PM
Drisean
All Things Towing
May 30, 2017 05:38 AM
sirrattles
Apr 2, 2012 07:07 AM
ed from houston
Feb 8, 2008 09:26 PM
sbennett
All Things Towing
13
Nov 15, 2004 11:49 PM
