Anyone Running a ScanGauge II ?
You may find you don't need to install the ScanGauge II in your new truck. I used a unit in my 2006 F150, and it worked great. But most of the parameters I monitored in the F150 are available in displays in the 2017s. Tranny temps, multiple ways to view fuel mileages, and what gear you are in are all available in the 2017 displays. I don't think I will be using my ScanGauge on my truck, but may move it to another vehicle.
Are Super Duty gauges "real"? Anyone know for sure? I'd like to know as I'll be ordering one as soon as the '18 is available.
https://store.blendmount.com/blendmo...uged-p101.aspx
If your gonna order go through their selection process to assure you get the correct part
I just picked up my truck tonight
The little amount of time I had to play with the display I remember seeing a few items I would like to monitor. But that is a bunch of button pushing when the scan gauge shows 4 at a time. I think the scan gauge had 4 turbo temps that I might be interested in for the 2017.
On my 6.4L, I found that the coolant temp gauge would indicate straight up (12:00) regardless of whether the actual coolant temp was 180 deg or 225 deg. Thus, no better than an idiot light, and useless for looking for trends when pulling hard. So I set my Scangauge to view actual coolant temp, oil or tranny temp, EGT, and DPF temp. The latter in order to easily detect regens.
