P0174
Old Jun 5, 2017 | 12:27 PM
97explorerjunk's Avatar
97explorerjunk
P0174
Well i am at my witt's end here i have been getting a P0171 and a P0174 code lean bank 1 and 2 censer 2 i have replaced all 4 censers the 171 is gone but i keep getting the P0174 and it only comes on when i am on the highway after driving around 10 miles or so i got a freez frame of the data when it happen but i have no idea what i am looking at any help would be great and thanks in addvance
Old Jun 5, 2017 | 01:08 PM
Frdtrkrul's Avatar
Frdtrkrul
How are you doing power wise? Does it feel underpowered? Do you feel it vibrate from a misfire? Could be a weak fuel pump, clogged/restricted fuel filter or clogged fuel injectors.
Old Jun 5, 2017 | 01:17 PM
KULTULZ's Avatar
KULTULZ
Unhappy
A set code does not identify an exact problem, it only points you in the general direction of the problem.
You need the proper year FORD SERVICE MANUAL (and referring TSB's) which will give you the proper diagnostic charts/sequences to follow.
While the manual is not cheap, it is cheaper than randomly throwing expensive parts at it.
Not yelling, don't think I know it all but there is no other logical way unless you know a certified tech that has years of experience and works for beer.
Old Jun 5, 2017 | 01:30 PM
shorod's Avatar
shorod
Which engine does your Explorer have, and is it a 1997 model year like your username would imply?
-Rod
Old Jun 6, 2017 | 06:18 AM
97explorerjunk
sorry Shorod it is a 2002 explorer vin code "E" 4.0l EB no the power is still there it seems to run fine but it needs to be fixed before the inspection runs out but as for the freeze frame what am i looking at when what do i need to see ? thanks for the help
Old Jun 8, 2017 | 07:11 AM
97explorerjunk
Well i just replaced the PCV it was not working and blocked so we shall see how it go's will update after test drive but still don't know what i am looking at for the freeze frame data what are the peramiter for what i am looking at and where might i find them thanks again
Old Jun 8, 2017 | 10:34 AM
KULTULZ's Avatar
KULTULZ
Post
GOOGLE P1074 and you will get the info you need.
astecasphaltman
6.7L Power Stroke Diesel
18
Sep 12, 2019 07:32 AM
AVE8R
6.4L Power Stroke Diesel
19
Nov 20, 2013 10:44 AM
tomtek
May 12, 2010 10:40 AM
stahlecker
Escape & Escape Hybrid
May 7, 2008 04:56 PM
CR125Honda
Jan 26, 2007 11:01 PM
