Fan speed control
Old Jun 4, 2017 | 05:06 PM
Kurts12F150STX's Avatar
Kurts12F150STX
Trailering
Fan speed control
I have a 2012 F150 STX with the 5.0 I have noticed that the fan doesn't seem to work, or if it is there is very little airflow when the dial is on 1 or 2. It works fine on 3 and 4. Any suggestions as to what the problem may be.
Old Jun 5, 2017 | 08:34 AM
alloro's Avatar
alloro
I'd start with replacing the blower motor resistor since it's both an obvious possibility and cheap. If that doesn't solve it then it could be a bad dash switch/control or the wiring.
Old Jun 10, 2017 | 06:39 AM
beidle99's Avatar
beidle99
its the resistor. Got my part from Amazon, and swapped it while my daughter was at soccer practice. Its 2 or 3 8mm bolts and a wire harness (if I remember), all behind the glove box.
Lukes66
May 8, 2016 05:06 AM
JoeLariat09
2009 - 2014 F150
Aug 5, 2014 06:49 AM
paetersen
Oct 7, 2007 02:51 PM
docdonnyb
Mar 10, 2006 06:45 PM
175Ranger
Feb 12, 2004 07:49 PM
