TPS adjustment?
Old Nov 23, 2001 | 09:52 PM
Justin89's Avatar
Justin89
TPS adjustment?
[updated:LAST EDITED ON 23-Nov-01 AT 10:53 PM (EST)]ok i fond the tps on my 89(under the throttle body) my brother inlaw put a scanner on my truck because the check engine was on, it said TPS out of range and there issomething wrong with my EGR so we are goin to fix that tommarow, already have a new TPS but i saw somewhere that if u adjust it to .9-.97 that the truck will have more power, is this true? a guy that i worked with said he did that to his mustang and that it helped.
Old Nov 23, 2001 | 10:25 PM
PAUL_2's Avatar
PAUL_2
TPS adjustment?
What engine ?
Old Nov 23, 2001 | 11:38 PM
Justin89's Avatar
Justin89
TPS adjustment?
it has a 302
Old Nov 24, 2001 | 12:30 PM
PAUL_2's Avatar
PAUL_2
TPS adjustment?
The best way to adjust them is scribe a mark before you remove an adjustable Tps . Try this , KOEO , Measure the voltage at the thottle position wire (GY/W Wire ) & the Signal Return Wire ( GY/R ) . With the throttle closed the min voltage should be 0.20 , wide open throttle the voltage should be 4.84 volts .
Old Nov 24, 2001 | 08:37 PM
jak1212's Avatar
jak1212
TPS adjustment?
Chefsteele
168
Dec 18, 2013 10:29 PM
1badshovel
Apr 17, 2011 06:01 PM
gmk035
Mar 14, 2010 06:09 PM
djdurrett
1997 - 2003 F150
Mar 5, 2002 08:37 PM
djdurrett
Electrical Systems/Wiring
Feb 23, 2002 06:17 PM
