Blower Motor/AC help
Old Jun 4, 2017 | 12:46 PM
rangerarnold's Avatar
rangerarnold
So I have a 2002 e350 bus, the ac and everything was working fine until I put in a new battery. Although I am sure one has nothing to do with the other, I now have no air blowing at all. Checked all the fuses and relays, the motor will blow with a jumper to the negative terminal of my battery, but now no cold air is coming out. The **** was successfully changing between on/off and air locations on the blower. I also have a CARRIER ac unit in the back which seems to only work when I move around a loose relay attached to something having to do with the starter. Any suggestions or ideas would be greatly appreciated as I am converting this bus into my home, and my cat doesn't particularly like the heat. THANK YOU!
Bdomangue
Jul 14, 2019 12:39 PM
Texascowboy77
Feb 4, 2019 07:18 AM
lanncz87
1997 - 2003 F150
Sep 4, 2010 08:32 PM
f100guy
Dec 5, 2003 12:25 AM
